engine change out will it work
dudley wallace View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dudley wallace Quote  Post ReplyReply Direct Link To This Post Topic: engine change out will it work
    Posted: 30 Mar 2011 at 1:16pm
i have an engine out of a e gleaner combine what tractor will it fit and what will i have to change i have a wd45 with a bad engine thanks for your help dudley.
a member of hendricks county antique tractor and machinery association club.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2011 at 2:26pm
yes it will, youll need the govenor, water pump, front pulley off the WD45 eng.  You have to space  the water pump pulley out about 1/2 inch to line up with the crank pulley as the crank snout on the gleaner eng is longer.
myallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote myallis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2011 at 3:54pm
Remove fuel pump and make a cover for it this is where the steering shaft goes through. The crank pulley you can do as the other guy said and space the water pump or you can bore the center of crank pulley and shove it on to line up with the water pump or just cut the end of the shaft off and slide the pulley on. If you do this you will have to drill a small indent to hold the set screw on pulley to crank shaft. The governor you can either pull the front cover off the 45 engine on put on gleaner engine this will require boring i think 2 holes bigger on the cover because of bigger bolts in gleaner engine or use the gleaner cover an put the throttle shaft in where the soft plug is this usually with have to have a bushing to make it tight in the hole. Steel line for oil need to be turned/tweeked a bit to clear the steering shaft or I replace with knew compression fittings and flexible oil resistant air brake line. The governor weights in the combine engine come to a point not ramped like tractor engines so I switch these out also. I think I covered it all.
cougar766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cougar766 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2011 at 5:29pm
gee wiz brother  I see how I rate you don't even let me in on this, I'll remember you
Post Options Post Options   Thanks (0) Thanks(0)   Quote myallis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2011 at 10:02pm
? I'm sorry was just trying to give a guy a helping hand and options didn't meen to offend anyone. I love this site.
AdamA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AdamA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2011 at 10:16pm
Not sure but I think cougar766 was making a sarcastic reply too dudley's post, looks like they are both from the same town?
57'D-17,78'185,83'6080,76'7040,84'8030 FWA.02'Dodge cummins
Post Options Post Options   Thanks (0) Thanks(0)   Quote cougar766 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 7:53am
I was harassing Dudley, we normally get into these thing together, sorry didn't mean to upset anybody
Post Options Post Options   Thanks (0) Thanks(0)   Quote myallis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 8:10am
haha. Thats good .  None taken. I didn't want to either
This page was generated in 0.128 seconds.
