WD 45
AC190XTrescuer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC190XTrescuer Quote  Post ReplyReply Direct Link To This Post Topic: WD 45
    Posted: 30 Mar 2011 at 6:24am
hi i was just wondering if all wd 45 came with power steering or just the later models?  And does any one know of any for sale in new york?
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2011 at 6:35am
You could get PS from the factory, but it was an option and not all had it. D19 was the first AC tractor to offer PS as standard equipment.
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2011 at 10:17am
I don't think it was available as an option until 1956. There are a lot of earlier models including WD's that have had the factory PS added.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC190XTrescuer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2011 at 6:36pm
can you add powersteering to the tractor if it doesnt have it?
What you cant get done today you can always do tomarrow, And if there is no tomarrow it was a waste of time today
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2011 at 6:43pm
Yes but if you want factory type it's not cheap, usually see them for around $500 or more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2011 at 6:55pm
There are other options if you want power steering but don't need the "factory" set up.  CHAR-LYNN units have been around for decades and are available new or used.
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2011 at 7:19pm
I bought a setup just like this for $500 for my WD.
You will think you are on a different tractor.
Even comes with a double pulley. A new pulley is worth about $200.
Char-Lynn torque generator is about $500.
The mounting brackets are there also plus the bent actuator rod that goes around the torque generator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2011 at 7:26pm
Last summer at the Amana Ia show, someone had everything needed to put P/S on a WD45 and they were asking $1000 for it all.
Matt (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2011 at 7:44pm
I bought a complete factory unit form Iklenborg Salvage in Aplington IA for $500 dollars about 6 years ago.
1955 WD-45 with factory PS
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC190XTrescuer Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 6:24am
thanks for the help
