CA Lever/Crooked?
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Topic: CA Lever/Crooked?
    Posted: 28 Mar 2011 at 5:49pm
I have this CA shift lever to sell, As noted in pictures it is "bent", I'm asking a silly question [ mind does not remember well anymore] I assume it is suppose to be straight, correct? Thanks for help. PS. OK to heat [lightly] and straighten??
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 6:14pm
Well if Im right the little thing on top thats "bent" is not sposto be there the ball that it is conected to is the real top of the lever. The top peice is a homemade add on.
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 6:21pm
RW....turn your monitor upside-down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 6:22pm
The unpainted end goes inside the trans and is not supposed to be bent like that...
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 6:23pm
Is that how its sposto go? Iv never seen one and that looked like the top! lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 7:10pm
Thanks, Brian, Someone had strong arms that this lever was attached to.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 7:19pm
You do not have to use heat ,just stick in hole and bend back . They are tough. I restored and custimzed a B and had to bend that lever almost like one on a D14 and i bent it cold.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 7:27pm
Cold bend it is, better that way.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2011 at 8:21pm
That is bent the same as on 1 of my  CA's. Bob
