844 ci engines ; BIG AL
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 844 ci engines ; BIG AL
    Posted: 25 Mar 2011 at 12:04pm
Is there any difference in a BIG AL truck engine compared to an engine out of a crawler or scraper ?
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 12:05pm
i would think so as BIG AL was set for 450 flywheel HP, so I am sure the pistons/nozzles would be different
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 12:20pm
The info I have seen says it was avaliable at 350 to 450 hp ; but also 2 different styles 21000 and 25000 ; I guess turboed and intercooling did that ? Maybe ?
big al View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote big al Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 11:37pm
yes,depending on application,ther can be a number of differences-oil pan&pickup,accessory brackets & pulleys,exhaust manifolds,turbo pressure tube,oil manifolds,front engine bracket,flywhl housing,flywhl to accept truck clutch,inj pump&gov.settings.the basic engine and cam are the same.the best crank is from a 1974 or newer truck or scraper application.the best crank is a snub nose which would make you turn to a 6138.they did alot of updates between 69-74,so i would search for a engine 74 or newer.you might have to round up parts from several differant engine apps to complete a truck app.i even got parts off a 4w305 for my rebuild.the hardest part to find would be the flywheel to accept the 15.5" spicer clutch.if you need help give me a shout.219-405-3286 jack
This page was generated in 0.494 seconds.
