Front Axle
OrangeKiwi(NZ) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeKiwi(NZ) Quote  Post ReplyReply Direct Link To This Post Topic: Front Axle
    Posted: 24 Mar 2011 at 4:59pm
This tractor has appeared for sale on a NZ website. At first glance it looks to me like a model CA but no tractors of this model came to NZ. I know the photo isn't very clear but can forum members make out whether it's a genuine CA axle ? Maybe it's a wide front off a WD or WD45 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 5:09pm
How can you be 100% sure none ever came ? You wouldn't believe how easy it is to import/export 'stuff', especially 20,30 40 years ago......
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 5:14pm
That is a C the C has an adjustable wide front looks much like a CA. The Wheel leaning against the Wall is For a C A CA has Power Shift Wheels. and 6 Lugs instead of 5 On A C
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeKiwi(NZ) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 5:17pm
We have a list of the original owners compiled by the NZ distributors. No CA's appear on this list and I haven't heard of any recent importations.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeKiwi(NZ) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 5:22pm
I noted the wheel centre of the tyre leaning against the wall, too.
So Dave, you're saying there was a wide adjustable axle for the model C ?
Dave Everett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Everett Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 5:26pm
Yep
I had one here in England also
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 5:36pm
BTW you can also verify that it has a 3 speed trans.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeKiwi(NZ) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 5:50pm
Learn something new every day. I didn't think there was an adjustable front axle for a model C but I've just found a photo of one in Norm's book. Thanks for the comments.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 9:06pm
You can also see the C seat, same as a B. Bob
allis restorer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis restorer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 9:11pm
and a CA has a Platform also the C did not. Steve
Go orange or Go home!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2011 at 9:31pm
Somebody enlighten us on the front wheel centers.  They look like a cast wheel center.
The fenders are different too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeKiwi(NZ) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 3:45pm
Charlie, I'm too far away (wrong island) to view the tractor but I think the front axle centres are off the early B's (1938 and 1939) The fenders are home made.
Because we think the front axle is factory made, I hope the tractor doesn't get an one way ticket to China. Current bidding stands about one third of scrap price.
EricPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 3:53pm
odd thing is unless the tires were mounted backwards the one leaning on the wall goes on the right side but the left side hub is missing from the tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeKiwi(NZ) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 4:36pm
They do some strange things in that other island LOL
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 4:43pm
I'd like to see the rest of the Chebby truck in the background.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 4:59pm
Do I see an extra hole in the hood in the second pic and is that a starting tank where the battery goes? I'd sure like to have those seat springs and a piece of the material if it's original.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 10:18pm
Eric, the wheel center can be bolted on either direction cupped in or cupped out so the one leaning against the wall could go on either side and still have the tyre facing the "right" direction. The spacing would be wider mounted on the left.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 11:46am
Most of the model C's that you find in WA and surrounding states are wide fronts or single fronts.  I have 4 or 5 wide front C's, 4 single front C's and one narrow front C. The wide front alone should be worth $3-400. Good luck!
ALLIS EXPRESS!
This year:
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 11:58am
I was wondering about the cast front wheels also, I never saw anything like that except on a G.  Could someone have imported it themselves.  Maybe got fed up with the US and immigrated to NZ.  Or maybe just built it out of odds and ends AC parts.  It would be  shame to send it to China.
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 3:10pm
It might be that New Zealand had import laws like Australia.  If you were to import a Studebaker, since the starter and generator could be purchased in Australia you could not import them with the vehicle. So if there was a manufacturer that made front wheels to fit, maybe you could not bring in the Allis wheels.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 5:54pm
No CA cultivator mounting bosses in the radiator shroud. Definately C wide front.
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeKiwi(NZ) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 6:32pm
JohnCO, I have 2 1938 B's with cast front wheel centres so I think it's like you said, a tractor made with many AC parts.
Charlie, NZ import laws weren't like Australia's. Our AC came fully assembled but had to contend with high tariffs (making them pricey) to protect English Fordsons and Internationals from competition.
I think I have a local (to the tractor)interested in buying it. To save it from scrap. I may do a deal later if transport can be arranged ?
