OK last post about hyd pump
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: OK last post about hyd pump
    Posted: 19 Mar 2011 at 4:45pm
on the 19. I had put it back together and was compressing the big spring with the pump in a vise when something hit me on my foot. It was the pin that holds the rollers onto the assembly. I then took off the 4 follower assemblies and tig welded the pins so they can't come out now. Once a pin comes out and the roller falls off all heck breaks loose!
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2011 at 9:05pm
So what are you going to do about the lobes that were destroyed? Bob
Dean(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2011 at 9:12pm
You may want to flatten 2 8 P galvanized nails and then hold down two
cam followers and insert the nail to hold 2 down with one nail. Let the heads of
the nails go out past the edge of the mounting pad so that after you get the
pump installed and the nuts just started, you can pull the nails out. I hope
this description is clear enough to follow. HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2011 at 9:16pm
Dean, your method works with a WD/WD45 pump, but this is the belly pump on a D19.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2011 at 11:35pm
Recon Dana got in there with an angle grinder and "trued" em up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2011 at 6:41am
I did grinf, file and sanded but I am still not sure what we are going to do. Thanks, Dana
This page was generated in 1.082 seconds.
