speaking of a 7030 look what followed me home!
Chris WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris WI Quote  Post ReplyReply Direct Link To This Post Topic: speaking of a 7030 look what followed me home!
    Posted: 17 Mar 2011 at 7:50pm
look at the newest addition to the fleet! let me know what you think. In the picture I have already removed the floorpans, and steam cleaned the tractor.  I have never see so much greasy crud on a tractor in my life! Next step fix the rear end, spiders must be bad,  without the difflock button down, the tractor does not move and makes all kinds of bad noises. does anyone have any pointers as how to go about such a fix?
Darb210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darb210 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 7:57pm
love the look of the 7000 series open station!!
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 8:15pm
Good rubber, reasonably straight tin. That could be a sharp tractor with some paint, a seat and maybe a chrome stack. Nice find!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 8:44pm
You can drain all the rearend oil (3 drain plugs) and completely remove the lefthand hydraulic filter assembly and with a flashlite look inside.  Jack up one rear wheel and rotate it to see what's bad. I'd guess you'll be removing the lift arm hsg and both axles to repair any differential problem. Hopefully you'll not need to change out the pinion.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 8:45pm
That is one tough looking SOB! Thanks for sharing. ED.
ac_bowsers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_bowsers Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 8:51pm
Damn I wish I would have bought that 7030 from my college buddy a few years back, it was a twin to that.
Agreed ED, those are the toughest looking open stations of that era
Pine Stock Farm "Home of the ALLIS" 35-WC-36-U-37-UC-47-C-49-G-57-D17-58-D17puller-63-D21-71-210puller-79-7045-83-8070-AA9675-BigTen-B10-310-1300fieldcult-snapcoupler imp.-longhopper blower,signs,etc.
Andrew(southernIL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 9:46pm
Like the rear rubber, and you should thank that grease and crud for preserving the paint..lol
If fishing is a sport your looking at an athlete
