262 Engine
willard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote willard Quote  Post ReplyReply Direct Link To This Post Topic: 262 Engine
    Posted: 17 Mar 2011 at 12:00pm
I have a Gleaner F Combine going to the scrapyard. This was a parts machine for me for my newer F. The parts machine has a 262 Gas Engine that is stuck, I dont know the history of the engine. Is there any value or should I just let it go with the machine. I appreciate all of your thoughts, this is a great place to ask questions.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 12:25pm
Save it,  the block, crank, sleeves are the same as in a 262 diesel and usually the gas blocks dont have the sleeves sinking.
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 1:08pm
Yes, save it.
B212,716,two 314H's,WC,WD,D19,190XT
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 1:38pm
Yep save it.  It's worth more as an engine than it's worth in scrap iron weight.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 2:14pm
 Pull out the plugs and add ATF to the cylinders . It may free-up in time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 6:41pm
I used a gas block to fix my D262 for a D17.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 7:46pm
The 262 gas pistons are NLA, and are worth salvaging.  Sleeves are still available, but the pistons are impossible to find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote willard Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 9:07am
Thanks for the replys I appreciate the Ideas. I will probably save this from the scrap man.
This page was generated in 0.297 seconds.
