AC 5030 & 5040 Parts Avalibility????
OrangePowerGA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangePowerGA Quote  Post ReplyReply Direct Link To This Post Topic: AC 5030 & 5040 Parts Avalibility????
    Posted: 16 Mar 2011 at 6:23pm
I'm in the process of buying a house and about 7 acres in north GA, and will need a small tractor.  The WD will be in the shop at the house for TLC and my other tractor is staying at my parents house to maintain the property and plow.
I'm looking for something that's going to be maneuverable with plenty of power to bush hog, finish mower, plow food plots, maintain a long driveway, etc.
Are parts for the 5030 and 5040 easy to come by and are they in general good tractors.  I'm open to suggestions and recommendations for other make/models as long as it's not a Deere.
Thanks
AC - WD
JD - 650
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2011 at 10:05pm
The 5040 is basically a Universal (from Romania) tractor painted orange.  Personally, I would look for a D15 series II (46 hp gas).  Parts are a lot easier to find for them, and you'd love the power director!
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangePowerGA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2011 at 10:25pm
I've heard good stuff about the 5050's but thing it's more hp than I need.
Any opinions on the 6140 or 160.  I'd like to go with something newer than a D series.
Are UTB tractors not any good?  Were these 5040s built to AC specs, basically built better than a UTB?
AC - WD
JD - 650
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2011 at 10:45pm
I think only 499 6140s made it to the states from Japan - Very scarce.  There are plenty of 160s around, but parts supply is a problem.  The 5040s were not built to AC specs as far as I know.  That same Universal tractor was also a White model (and a couple others).
Lyle124 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lyle124 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 7:10am
I've got a 5040 and haven't had any trouble getting parts for it. A lot of Long parts will interchange also. Lyle
5040 Bad Boy Mower
sandylakeimplement View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandylakeimplement Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 11:55am
Several sources for 5040 parts and they were a great tractor. Parts for the 5030 are iffy and pricey although it too was a good tractor.  Bill
Sandy Lake Implement
Sandy Lake, PA
724-376-2489
www.sandylakeimp.com
FIND US ON FACEBOOK
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 12:56pm
I looked at a , I think 3010 New Holland ,  looks like a Fiat 5040 with different sheet metal.
indiana2door View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote indiana2door Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2011 at 8:48pm
Oliver Super 55 or 550. Best utility tractor ever built.
AC190XTrescuer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC190XTrescuer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2011 at 9:02pm
hi i have a 5040 and i love it it is my baby it is a great tractor parts are pretty avilable and i use mine to spread manure with our new holland 155 spreader which is rated for use of at least 50 hp but she runs it fine
What you cant get done today you can always do tomarrow, And if there is no tomarrow it was a waste of time today
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 6:44am
the 5040 was built in romania, it is basically a copy of a fiat tractor, that was marketed with the allis chambers  colors, it is comparable to the 1250a/1255 oliver/cockshut tractors.
i have a 1970 model, fiat built oliver model 1355, that has been an excellant tractor, it has given over forty years of superior service, the only thing i have rebuilt was to put a new thrust bushing in the front end.
there is an excellant parts source for the tractors online at import tractor parts, and they have a very good primer on these tractors as to what to expect in these tractors
so i would go to the website and do a little reading http://www.importtractorparts.net/buyersguide.html
Edited by ky wonder - 18 Apr 2011 at 6:49am
This page was generated in 0.104 seconds.
