1967 Allis Chalmers D17 starting solenoid problem
EJBlaze82 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EJBlaze82 Quote  Post ReplyReply Direct Link To This Post Topic: 1967 Allis Chalmers D17 starting solenoid problem
    Posted: 16 Mar 2011 at 12:51pm
I have a 67 D17 gas and my starting solenoid went. I got a new one but cant remember wich way it goes in...can it be put in upside down?? i have wire from starter to one bigger bolt batt. wire to other large bolt and the 2 small wires. i also have wire coming from guages that i belive goes on with the batt. wire? im lost and any help would be nice haha
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2011 at 6:36pm
The solenoid won't care which way the power goes through. The wire to the ammeter needs to be on the same side as the cable from the battery.
Post Options Post Options   Thanks (0) Thanks(0)   Quote EJBlaze82 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2011 at 8:04pm
ok thanks i will try that tomarow. i was talking to someone to see if the new solenoid was in working condition and they said there should be no continuity from either bolt to ground. is that true?
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2011 at 9:40pm
That is correct
If you find any resitance at all to ground of large studs, it is bad.  On some models one of the small bolts will be tied to chassis ground, on some the whole coil is isolated from the chassis.
Edited by Orange Blood - 16 Mar 2011 at 9:41pm
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote EJBlaze82 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 7:52am
i have the solenoid hooked up and i still get nothing with the key....bad key switch? this things got me stumped
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 10:03am
Keep in mind that this is a 12 volt POSITIVE ground system.
The large terminal on the battery side of the solenoid is "hot" at all times. If you jump a wire from it to the small starter terminal on the solenoid, the starter should engage. MAKE SURE TRACTOR IS IN NEUTRAL!!  If the starter engages in this test, then you must have a problem with the starter circuit in the switch. If you connected the wire coming from the ammeter to the hot side of the solenoid and all the wires  in the wiring harness are hooked as they should be, you will have 12 volts at the input side of the ignition switch.  If you connect a test light from the ignition switch starter terminal to ground, it should glow when ignition switch is turned to the start position.
I am attaching a wiring diagram from my D-17 Manual. These older tractor wiring systems are pretty simple and you should be able to diagnose your problem fairly readily.
boscoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 9:09pm
OK  I got a similar question, on my  190 gas i cant get the engine to shut off when i turn the key to the off position. I tried a different keyswitch but no difference, does it matter if the starter is from a combine?
1959 D 17 gas , 1964 190 gas, 1965 190xt gas AC 4bottom slat plow, 6 row 30in #72 planter Im not getting bigger my cloths are just getting smaller.
