185 tractor opinions
mjbower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mjbower Quote  Post ReplyReply Direct Link To This Post Topic: 185 tractor opinions
    Posted: 13 Mar 2011 at 11:54am
we looked at a 185 today that needs engine work believe that it has the 2800 engine in it noticed that the engine kit is more than the 2900. is there pros and cons with this tractor thanks for any info.
jb from md View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2011 at 2:36pm
Im not sure about your engine question but I have a 185 and use it for everything from mowing and baling hay to pulling wagons, right now it has  the log splitter on it. it is the most versitile tractor we have. dont get me wrong they all have their job to do but it seems the 185 is big enough to plow and small enough to rake hay ...jmo...Jb
8050 FWA, 190XT, 185, Styled wc, Unstyled wc, (2)C, (2)WD45NF, WD45WF, WD,416h, 716h, 312h, 8070 pedal.
Frank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frank Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2011 at 3:11pm
Great Tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2011 at 6:05pm
185,S are great tractors ; good on fuel , can handle big farm jobs , right along to the hay rake as stated ; what kinda engine issues does it have ?
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2011 at 8:04am
As stated by others -- great tractor. Have used mine for just about everything  - plowing, discing, bush hogging, hay mowing, raking, baling - square and round. Easy to operate. Just a nice all around tractor. It's not my only tractor, but is my favorite to operate. Have had few problems -- whats the engine issue?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2011 at 8:07am
Oh yeah, have also used it with a seed drill and harvesting with an All Crop 60. Just very versitile machine --- and wife can run it.
bill2260 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill2260 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2011 at 8:17am
Great tractor. Some things to check are brakes, pto, blow-by, steering cradle will break after time. Great tractor to operate. Bill
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2011 at 9:14am
The rear of the front axle yoke can be prevented from breaking if you weld in 1/4" thick or larger gussets in each corner. The gussets don't have to be very large. I can still get the oil pan off Dad's 190XT after it was repaired this way. None of our other 190's have had any problems. They all don't break but if it has a loader on it there's a good chance that it will or if you are a fast driver over rough ground like some guys are.
Edited by Lonn - 14 Mar 2011 at 9:19am
Wink
I am a Russian Bot
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2011 at 9:23am
They are a great tractor, you won't go wrong with one!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mjbower Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2011 at 8:59pm
is the 2900 turbocharged and the 2800 natural was just wondering because of the price differnce in the engine kits thanks for the input
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2011 at 2:58am
A natty tractor will run a higher compression ratio due to the lack of boost pushing air in it.... might be the difference?!?!?
