Plus and neg of the Deutz allis 9100 series
Joe Graunke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe Graunke Quote  Post ReplyReply Direct Link To This Post Topic: Plus and neg of the Deutz allis 9100 series
    Posted: 13 Mar 2011 at 7:40am
I'm looking at a Orange Deutz Allis 9130 or a 9150 with FWA what are some things to look for. Any thing good about them.
thanks
Joe
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2011 at 9:40am
The engine is wonderful until (or if) you have trouble with it. The rest of the tractor is rugged but a dry foot clutch and a non-power shift transmission. Also the FWA engage isn't on-the-go. If you are moving up from an old 7040-7045 with a Power Shift trans, you might think you went little backwards, but gaining an FWA. If you are moving up from a Power Shift 8030 FWA or 8050 FWA, you are going backwards.
Brian(Va) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian(Va) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2011 at 7:50pm
We have a 9130 FWA, it is a simple but tuff tractor.  I'm looking for another one also.
MUM FARMER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MUM FARMER Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2011 at 8:45pm
Try to find 9130 that the pump hasnt been turned up on at under 150hp the motor will last along time the 9150s were on the edge at 150 plus hp and if they were turned up they had problems streching head bolts the 374 engine is very good also for those that own them to the left of the turbo is a thermostat that sends oil to spin the cooling fan there is a 10mm bolt with washer unscrew take off washer and screw back in this will send oil continually to fan you might use a little more fuel but you wont have an issue of fan not spinning due to small  piece of contaminate in your oil causing potential overheating
cms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cms Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2011 at 3:32pm
We have 9170 Deutz Allis orange version. Purchased it used for Ohio. Look at the brakes and drive around applying them. If they squeal or are grabbing they will need to be replaced, which entails splitting the tractor. Learned this out the hard way, brakes were dropping metal chips into the transmission and locking it up so that it would not move. Dealer split the tractor 2 times before finding this. They are good powerful tractors that will work. On the down side they don’t turn short and don’t start easy in cold weather (40 and below). The cabs are very quiet and you won't ever have to fill a radiator or repair leaking sleeves( air cooled).
Edited by cms - 15 Mar 2011 at 3:43pm
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2011 at 8:28pm
from behind the clutch, it is a WHITE tractor, including the over/under 3 speed power shift. Should be a very reliable tractor, and the WHITE cabs are pretty nice.
ac_bowsers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_bowsers Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2011 at 8:38pm
Keep engine clean, and replace valve cover gaskets about evey 3 years, use good oil and change at proper intravels those things will last for ever!!!. Updated version of a WHITE tractor like ed said. We have a Deutz engine in our GLEANER, never have had an issue tough torqing engines.
Pine Stock Farm "Home of the ALLIS" 35-WC-36-U-37-UC-47-C-49-G-57-D17-58-D17puller-63-D21-71-210puller-79-7045-83-8070-AA9675-BigTen-B10-310-1300fieldcult-snapcoupler imp.-longhopper blower,signs,etc.
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2011 at 8:47pm
We owned a 9190 for 13 years, it was 4 yrs. old when we bought it, fluid all the way around including the frnt. tires, it would pull right with our 8550. Doc's right about the deutz engines, you have to account for every little leak or you will have high dollar trouble later. The chassis is basiclly a WFE 2-155,2-180. Also as talked about the brakes need to be updated if they are expected to live on the fwa tractors, alot of this was caused by the longer wheel base. The 9170/9190 tractors are like a 8070 fwa on steroids. , Mike
This page was generated in 1.162 seconds.
