WD45 D injection pump pressures
joy2all47 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joy2all47 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 D injection pump pressures
    Posted: 11 Mar 2011 at 3:20pm
 Hello Everyone....
We are needing to know the breaking pressure on the injection nozzles on our  WD-45
Thank you
Joyce in Canada....
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2011 at 3:29pm
2,000 PSI w/ even spray pattern
Post Options Post Options   Thanks (0) Thanks(0)   Quote joy2all47 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2011 at 3:35pm
 Thank you Chris....
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2011 at 3:44pm
The spray is  conical spray with a fog in the center at 4 inches from tip. - 2000 with calibration oil, Think it was 2300 when testing with diesel fuel.
 If it does not drip at 1700, its considered good - at least thats what the old book said.
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2011 at 5:13pm
This is a cutaway WD45Diesel head of David Ferguson's we had under the tent at Hutchinson.  We had it hooked to a tester and got the camera to snap at the right time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2011 at 6:26pm
Tom, Cool picture, Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote joy2all47 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2011 at 6:36pm
Thanks Everyone for your help......
Thank you for the photo Tom....now I know what it looks like....
Joyce
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2011 at 7:17pm
It's amazing those old diesels ever ran why without any valves, and most of the fuel going out the other side of the head?!  :)
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2011 at 7:20pm
Tom, thats kind of what it does look like, but the ones I checked would chatter as pressure was built up, the spray you have looks like a hard handle push to get the time long enough to snap the picture. ... But that pic is still way cool, I really like it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2011 at 7:23pm
OB, thats the modern going green theme there, doesn't make no black smoke
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2011 at 8:02pm
ive always wondered what it looked like, we just did my dads 45 diesel injectors they all tested around 2100 to 2200 psi with new tips
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2011 at 8:22pm
That is lots more fuel than a running tractor would use on one injection for sure.  We took several tries to get that picture, it was fun when we got one to turn out.  Thanks.  Tom
