7040 AC
golddog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote golddog Quote  Post ReplyReply Direct Link To This Post Topic: 7040 AC
    Posted: 10 Mar 2011 at 7:36pm
my 7040 is a powershift and after you run it for awhile reverse quits
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2011 at 8:22pm
Can you be a little more specific about "quits", does it slip, or not engage at all, handle won't move, etc.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote golddog Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2011 at 11:32am
it hesitates engaging then stops pulling but its only in low range seems to me like its in the valve body
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2011 at 4:35pm
If it does it in Low range, it almost has to do it in high range and even worse in high. First of all it has to be full of oil and the dipstick is in the cab to check and add oil if needed. How many hrs are on it??? anything over 5000 hrs might dictate re-sealing of the tranny and it possibly might have broken clutch discs in the rev clutch pack which could be determined by removing the valve body and looking at the rev clutch pack.
