D17 WONT START
THREESHOT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote THREESHOT Quote  Post ReplyReply Direct Link To This Post Topic: D17 WONT START
    Posted: 10 Mar 2011 at 7:06pm
Hey I'm new here but I have a problem.  My D17 cut off in the field and would not start back again.  Checked the gas had plenty, now since then I have walked it back to the barn because it would not start and run.  I have cleaned the carbureator installed new fuel line and fuel filter still wont start.  Installed a new coil still wont start.  Now I have some smoke coming from what I assume is the starter solenoid so what should I do?  Any suggestions are welcomed.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2011 at 7:30pm
Let it cool, overcraking will burn up the contacts.  I am guessing that you have an ignition issue.  Give her a small snort of wd40 in the intake, if she fires, it's carburation, if it doesn't it's ignition.  Could have a short to ground on your points, a coil wire came loose in the cap, bad rotor, points came loose won't open.  lots of things, my guess is ignition, that's typical when they die suddenly.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2011 at 6:48am
You need to know what's missing. It takes fuel, air, compression, and a properly timed spark. Pull the coil wire out of the center of the distributor, lay it within 1/4" of the engine and carnk the enigne over. You should see a bright blue spark jump. No spark, check for power to the coil with a test light. Got power, probably time for a new set of points and condenser.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2011 at 7:19am
I'm wondering how you walked it back to the barn if it would not start and run?  Or is running but poorly?
I would aslo give it a shot of WD40 or starting fluid in the intake and see if it wants to run.  You need to determine if it fuel or ignition and doing this will eliminate 50% of the possible causes of it not running.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
paulinkansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulinkansas Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2011 at 9:07am
I've had similar problems with my D17 gas.  The way I fixed my problem was to spray some battery terminal cleaner into the ignition key slot and let it soak for a few minutes.  Then I spray it out with carb/brake cleaner to remove the battery terminal cleaner.  Then I give it a squirt of battery terminal protector.  This last step may not be necessary, or may be substituted with wd40.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2011 at 9:58am
If no spark,try a different condenser.
This page was generated in 0.158 seconds.
