Question for mechanics
BWinMO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BWinMO Quote  Post ReplyReply Direct Link To This Post Topic: Question for mechanics
    Posted: 10 Mar 2011 at 3:20pm
D 19 gas cam gear has 2 different timeing marks on it 1 dot on one side then 180* 2 dots which do I line up with crank gear dot. If I line the 1 dot with crank when you turn the crank a revilution to hte 2dot you are off 1 tooth. So which do I line up the single dot or the double dot with crank.
   Thanks in advance  B W
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2011 at 6:30pm
Which ever one puts the cam lobes for cylinder one on the power stroke.
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2011 at 8:34pm
Hello BW   I'm note sure on this motor ,but I would see if the 2 dots lineup on each side of the single dot.   Just a guess
Post Options Post Options   Thanks (0) Thanks(0)   Quote BWinMO Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2011 at 9:14pm
The 2 dots are on the same gruve one above the other.
 Thanks B W
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2011 at 12:27am
 If i rember right line up the single dot with the crank. The 2 dots are for the injection pump on the wd45 diesel.  Matt
This page was generated in 0.146 seconds.
