What is a WD, WD45 tire/rim worth?
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Topic: What is a WD, WD45 tire/rim worth?
    Posted: 08 Mar 2011 at 11:01pm
I know where a pair of tires with rims & centers off of a WD or WD 45 are. Tires aren't real good and I'm not sure about the rims as they're stacked one on the other.
What would a reasonable offer be?
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 11:34pm
Ditto
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 12:14am
Tires being not good and rims questionable, they're worth the scrap price of the wheel centers maybe.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 7:20am
I don't think they are worth that by the time you EVER can get rid of the scrap tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 9:14am
Ok, I don't think the tires are junk, just well worn. I can't tell if they are holding air because they're setting on an old flatbed stacked one on top of the other.
I could use them if they hold air, they look better than the ones on my WD. Or I could use one of the ceners for an early D17.
I'm thinking offer $50 and go to $100 for the pair?
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 9:28am
If you priced new 12 or 13" X 28 rims, you'd bring them home even if all that was left to the tires was the sidewalls! I just repaired a set of 13's that had the typical rot around the stems. A few hours and some patience can save you a lot of scratch. Don't forget that you have all of the clamps as well....and maybe the stops are there? If you could get the pair for $100....I'd say you got a steal. JMHO.
Edited by Chad(WI) - 09 Mar 2011 at 3:44pm
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 11:36am
I agree with Chad.  The eccentric clamps and stops on the PA rails are worth something.  I'd like to find some eccentric clamps for a CA (they are different from a WD or WD-45).
