8030 3pt hitch installation/option
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Topic: 8030 3pt hitch installation/option
    Posted: 08 Mar 2011 at 9:21pm
I looked at a 8030 without 3pt hitch on it.  It appears to have been like this from new.  What is required to add the 3pt hitch to it?  Does anyone know where I could get these parts? Used preferably.  It appears there is no valve nor lever in the cab, as well as the arms and lift rams and upper link mount bracket.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 10:38pm
I never seen an 8000 series without a 3 PT. Didn't know they ever made em that way
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 6:12am
Took me by surprise as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 6:26am
I'd guess you'd need a completely different lift arm housing including the internal ram and rockshaft along with a 3 pt hyd valve and all the linkage and then the torsion bar down below which would require removal of one of the final drive assemblies to install it. After all that is in place, then you could hang the 3 pt lift arms, links and lower draft arms.
Bill(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 7:01am
You could order an 8000 without 3 pt just the drawbar. Drawbar only with 2 remotes had a deduct of $2239.00. Weight was -661#.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 7:32am
Is this a picture of one without a 3 Point.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 4:20pm
Anyone know where I can find the parts Dr Allis listed?
Who has a wrecked 8000 series that you know of?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 5:19pm
All the parts from a 7040-7045-7060 would fit except the valve and hyd lever/linkage.
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 7:29pm
Amos try Fawcett Tractor Supply they have a 8030 in the yard.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2011 at 6:01pm
You can get an after market 3 pt. hitch that will bolt right on very easy. In Alberta - WSI Sales @ 780 999 3523 definitely can help you.
Ron
This page was generated in 0.154 seconds.
