D 17 WEIGHT
Dan53 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan53 Quote  Post ReplyReply Direct Link To This Post Topic: D 17 WEIGHT
    Posted: 06 Mar 2011 at 6:36pm
WHAT IS THE WEIGHT OF A d17 WITH FLUID IN THE REAR TIRES?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2011 at 9:09pm
Well, it depends on what age/series of D17.....gas or diesel.....wide front or narrow front.....3 pt or snap coupler....what size of rear tires and if they are FULL of fluid or half full, etc..........somewhere between 5000 and 6000 lbs.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2011 at 3:12am
My '59 D17 gas, wide front, and no weights with 16.9-28s loaded weighs 5800. With 15.5-38s on pressed steel not loaded it weighs 5000.
gcalent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2011 at 11:28am
Mine is a series 1 wide front with 18.4`s with fluid and weighs in at about 6300#
Pullin With AC
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2011 at 6:32pm
My 58 weighs about like Dans 7080 D17 does. Mine has no power steering but has 16.9x28 with fluid and no weights. My brothers 59 equipped the same but with power steering is about the same. Used to pull with these tractors.
Wink
I am a Russian Bot
This page was generated in 0.103 seconds.
