Snap coupler dimensions
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Topic: Snap coupler dimensions
    Posted: 06 Mar 2011 at 7:38am
Over on the "other" site someone  has asked about some SC equipment he has that has narrower lift arms than his WD.  Can anyone here confirm that the CA and maybe smaller D series had narrower lift arms than the WD and bigger D?  He said he's got a 2-12plow that measures about 3" narrower than his WD.  Would like to help the guy out, but I'm not for sure.
AaronSEIA
Jim-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim-Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2011 at 8:36am
The distance between the lift arms on a CA is less than on the WD-45. I had to modify the lift part on my snap-coupler blade to match up with the width of the lift arms on my CA. Also had to swap out the snap-coupler eye for a pin-hitch coupler from an old plow to fit my '51 CA with pin-hitch.
'61D17, '51WD, '51CA, '41C, '49C, Woods 5'&6'Mower, 6'Blade, CA-Plow, CA-Cultivator, 3-Btm snap-coupler plow, 4-row planter, WD 4-row cultivator, 80R mower,#7 mower,B/C mower
