How to repair U pivot on front end
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Topic: How to repair U pivot on front end
    Posted: 04 Mar 2011 at 9:04am
Here is a picture of the front bracket that hold the front axle and radiator.  I haven't tested but pretty sure the bracket is cast iron and also the front axle itself.  How is the best way to repair this and the axle.  I have the axle off, the hole for the pivot pin is ok in the center of the axle but both the front and back edges are egg shaped.  The front side of this bracket is ok.
(The picture was there when I proofed it, don't know  what happened, HELP Charlie)
Edited by JW in MO - 04 Mar 2011 at 9:21am
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 9:28am
The bracket is cast iron. The axle is forged steel.  You could bore both oversize and install bushings;  I would recomend steel bushings. The axle hole could be welded up and re-bored, but it's probably easier to bore it and bush it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 9:30am
You could bore and fit an oversize pin, but that front casting hole is worn too far for that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 12:48pm
OK so there has to be 2 brackets , one in front and one behind axle.  Looking at the hole , wear is on top so it could be welded up but both pieces then need to be bored so the pin lines up through axle. I would then make pin captive by welding a tab onto new pin to hold it from moving once set into re-machines front and back brackets .
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 8:02pm
Nice Avatar there Wendell.
Don
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 8:10pm
What is your casting # .There where 2 differan ones for the U tractor with the UM engine .The later one is taller .I have ove from a Power Unit ,ofcorse it is like new at the pin holes .Or if you can find one out of a P/u close to you it would be a easy fix  ,just make sure you check casting #
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 8:14pm
Coke the front support is all one casting ,just read your post
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 8:23pm
Here goes the second attempt at copying a picture, the front of the casting, #U-1645-8
Edited by JW in MO - 04 Mar 2011 at 8:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 8:32pm
JW ,send your picture e25_40@yahoo.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 8:43pm
Don
Funny how the background looks similar in both of ours huh!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 9:36pm
Will check the number on mine sunday .Leaving 5 am to pick up my new to me toy M Crawler in Vi.
Brad-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 6:35pm
I took mine to a good machine shop and had them bore both holes in the front casting and the hole in the axle out to make room for a steel bushing to be pushed into each.  You can not even tell that there are bushings in them when you look at it now...if done right, the repair will never be visible to anyone.
1930 U
1938 A
1941 WF
This page was generated in 0.101 seconds.
