Back row kids...( Ugly Tractors )
Eddie(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie(IL) Quote  Post ReplyReply Direct Link To This Post Topic: Back row kids...( Ugly Tractors )
    Posted: 03 Mar 2011 at 9:50am
   How about a tribute to those poor old back row tractors, that never got their chance
   in front of the paint gun, but would still give you a full days work if given the chance!
      This one is a good starter...if you look closely, it's a 45 diesel with p/steering that we stumbled on to here locally. It had a wood bench seat in the cab, and even a heater.
    The other is a little Ford 8N with the Funk mfg. 6cyl. conversion, we found a while back.  Eddie
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 12:22pm
man! they did alot of work...for a trip bucket loader tractor!! i'd take it! them little ford tractors look cute, but they have killed alot of people! everyone should have taken a class before operating them!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 12:42pm
Shameless, That is an 8N, I didn't know they caused a lot of deaths. The old Fordsons had a reputation of going over backwards but that was because of the geometry of the hitch point. I still hear people talk about the "dang worm drive making it tip up" but any differential can do that if you hitch too high and behind the axle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 12:46pm
Eddie, I think my 45 is in that class.
split51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote split51 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 1:15pm
Tucker, I think shameless was refering to the PTO with attachments like a mower pushing people through fences and over ravines.
1929 20-35 sn17662
B1 w/snow blade
B10 w/sickle mower
B110 w/mower deck
B110 w/tiller
B112 w/grader blade
B210 w/plo
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 1:19pm
Here is a pic of our D-19 gas.  It served my uncle well as a loader tractor for probably 20-25 years with very little trouble.  It has since been retired but we still use it around our place some.  Hope to get it restored someday, but its gonna be a lot of work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 2:16pm
    Never give up hope on anything...and always think ahead, even though it may seem like you'll never get there.  Here's a before and after of this 1962 D19 we restored...
   This is ugly!
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 3:27pm
It was easy with the Ford N series to hitch a hard pull to the three point links that would rise and raise the pulling point to tip it over backwards. If it had an optional draw bar on the bottom of the axle that and it was used it was harder to tip if over backwards. It was often tempting to run a chain around the axle when pulling a stump and that was deadly. A neighbor rented a Ford, probably later than an 8N with a brush hog and hooked it on a stump. It smashed him against the mower hitch. He didn's survive but the tractor wasn't even scratched.
Using a 3 point hitch on an Allis the same will make it tip the same way. Hitching a chain around the axle will tip the Allis faster than the Ford.
The PTO was very easily solved with the SAME overruning clutch that nearly every other tractor of that era needed on the PTO.
The N series was just way too light for real work.
Gerald J.
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 3:49pm
I have been known to hook a chain to about every part of a tractor.  Favorite is front axle on the D14 for light pulling of a rolling load.  The N series Fords were great little orchard tractors.  When pulling against a stationary object my dad showed us long ago to run the chain under the axle, over the transmission and hook back to the chain.  This way you are pulling the front of the tractor down.  (Be sure not to go over the brake and clutch rods or you get yelled at a lot.  So I've heard!!!)
joegrgraham View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joegrgraham Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 4:00pm
Maybe it's just me, but Hager's D19 looks lovely to me, every ding and scrape has a story, the tractors whole life is there, why go and bury it under pounds of filler and two-pack paint.  I don't mean to put anyone down, Eddie's done a stunning job on his tractor, I just prefer the 'lived in' look. If it ain't shiny, you ain't afraid to use it for what it was intended.
If it seems like a good idea, do it. It's easier to apologise than to get permission.
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 4:31pm
   This is ugly!
Are you sure that is the same tractor? Seriously, you did a great job. It really looks good now!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 4:56pm
    No Lie, Redline...it's the same tractor.  Once we got that nasty cab off it and removed the loader, the sheet metal wasn't that bad, and luckily, the previous owner had kept the fenders and grille.  Thanks for the compliment.
    Here's how the little 8N posted above, turned out...
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 4:59pm
Dad's '52 WD (with WD45 decals). It's pulled our little pickup truck out a few times, moved plenty of dirt with the bucket, and bush hogged 7 acres every year. It leaks fluid from everywhere and the back rims are about to rust to pieces, but it still does the job and someday I want to give it a good restoration and hook the #53 plow to it.
I can't exactly say that my B is pretty either. Hope to get it going this summer.
beeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote beeman Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 6:58pm
That B has alot of potential!! Why the rare , {probably dealer special option}calico muffler system looks to be in excellent condition. {Sometimes my own B gets the grey striped version ...}
1949 B   3930 Ford- Have owned other Orange ,green,red,yellow,dark green tractors and equipment.
David Gibson (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gibson (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 7:15pm
With that muffler she purrs like a kitten :)
David Gibson
http://www.darkecountysteam.com
1956 WD45
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 7:35pm
Eddie, I diddn't notice how much they raised the hood/grille until I saw the "after" pic. You did an excellent job. Lot of daylight between that hood and the head on that flat-6.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 7:55pm
This old girl can still do an honest days work and will never get in front of a paint gun as long as I own it!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 7:57pm
Phil, that's about as original as they get. She's beautiful just the way she is.
Jeff-in-Kunkletown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff-in-Kunkletown Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 8:08pm
Yes sir Phil, that old girl deserves to be left alone. That 45 diesel with the cab looks almost like it factory. Wouldn't want one on mine, but whoever put it on did a nice job.
Sucess is how high you bounce after hitting bottom. Gen. George S. Patton
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 8:34pm
I helped farm with an 8N when I was growing up here in Massachusetts. Neighbor had a couple of them. We made a lot of hay with them and grew corn for the cows. Made enough hay and silage to feed 50 dairy cows over the winter. All that work got done with those two little machines. I guess "real work" depends on where you are - here on the hill farms of New England would differ from out in the mid-west, I suppose!
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 9:50pm
Good choice Phil. I like the originals too. Everything I own has had some new, usually sloppy paint added to it at one time or another. I painted parts of the 45 when I had them off for repair more or less to keep the rust down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 10:20pm
yeah...what split51 says....been on soooo many rescue calls that that happened to the persons running them, not counting the ones i heard of around.
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 11:02pm
hey WJohn that is acool looking cat on the b there,looks like its dancing on the hood!
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 11:23pm
Sorry about the cat, guys... I took those pictures maybe half an hour after the tractor was delivered, and the cat was already climbing around on it. I think she's stretching in that picture. She's pretty good company when I'm working on the B.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 1:27am
A school classmate lost her mother when she hooked a chain on the upper link of a  borrowed NAA Ford and had her other daughter pull her backword with a IH M.  She didn't survive, the daughter has had a hard life since, divorced twice.  Got to blame some of the problems on what she helped happen to her mom.  In fact my classmate also divorced because of emotional problems.
Allis Express participant
jb from md View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 1:24pm
This is my 55 wd45 i cant be without it long enough to paint it
8050 FWA, 190XT, 185, Styled wc, Unstyled wc, (2)C, (2)WD45NF, WD45WF, WD,416h, 716h, 312h, 8070 pedal.
tomdavison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomdavison Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 1:49pm
I agree with Dave(in Mass)  We had a large number of farmers in NE Pa that had 8N and or 9N Fords.  In most of these farms (dairy) this was the only tractor they had.  These may hafe been too   small for larger midwest acres, but were good little tractors in this area  By the way, pulling trees or logs is dangerous with any tractor.  We had a couple killed pulling logs with a M.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 7:39pm
All my WD45's can't find a paint gun to make them look new and some of them last looked at one back in 1957. Boys that not rust on them, it's called pitiana! lol
Here's the one with the most pitiana on it. But she lives to cultivate corn. lmao
Don
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 8:04pm
Eddie, that D 19 is awesome!!  The D 19 is one of my favorite Allis tractors, and that restoration job makes me like em more. darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 10:25am
      Hey guys, thanks for all the responses and the compliments. As much as I like restoring tractors, some are just meant to be left in their work clothes, ( Alberta Phil's is the prime example). Heck, even I prefer to be in my work clothes!
     Seems I struck a cord with that photo of the 8N, and although 75% of our restorations are AC's, we've had a large demand for the little Fords. Even one, I'm proud to say that we did for the TV actor, Kirk Cameron in L.A., that he used in one of his movies.  Most are wanted for show and work duties, folks that have 10-20 acres to maintain, but still want something to take the kids to shows with.
   We have another 6cyl. Funk 8N in our shop now, and we're planning on refitting my dad's V8, 9N over to an 8N chassis this summer. Talk about safety issues, ( my father on a 130 hp 8N, with overdrive...I'd better start working on a Nascar style cage to put on it. Actually, any of the Funk conversions are fun, if you should ever get the chance to drive one.  Here's a couple of pics of dad's Mercury V8,...have any of you ever seen a rear-mount Dearborn loader like this one. I included the pic of us with Kirk, outside his home in L.A. Thanks again, and post more pics, Eddie..
