d17 diesel/gas conversion
junkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Topic: d17 diesel/gas conversion
    Posted: 02 Mar 2011 at 10:39pm
I drug in my first Allis yesterday and had a question that I thought someone could maybe help me with? It is a D17 diesel that someone converted to gas buy putting a 230 Budda in it out of a combine. My question is, does anyone know the draw bar HP this combination is putting out? thanks for any answers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 11:47am
That's kind of tough to say. The 230 diesel was used in the WD45, but usually the same displacement gas engine produced a few more hp. I'd be willing to bet it's going to be pretty comparable to an original gas D17.
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 8:17pm
I just assumed that the HP would be more since the engine had two more cylinders, but looking at the factory gas engine, I see that the bore and stroke was bigger in the  4 cylinder. I think the Buda engine was rated at 72 hp but at a higher RPM. But boy it just purrs like a well loved kitten. can't wait to find a plow for it and try it out, but have to have a 18 inch to match the tire width.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2011 at 10:04am
If it has 18.4-28's, a 16" bottom should be OK.
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2011 at 7:04pm
I thought it might work, but I have located a 18" 4 bottom slat plow for 250.00. Only thing is I have never used a slat plow before.  Any prows or cons on slat plows?
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2011 at 7:08pm
My uncle used to have one and we could not tell any difference in plowed ground. But if you have old sticky gumbo that won't slide off a moldboard like we have, it will seldom gum up like a regular board. You will probably never notice the difference if there is any!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2011 at 10:59pm
It seems one question leads to another somehow. Never owning a Allis or even driving one in my 40years, my knowledge is limited. will a 6 cylinder d17 with good 18.4 tires and no wheel weights pull a 4 bottom plow?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2011 at 11:55pm
It should pull a mounted 4 bottom. The "Traction Booster" system is what they have for a draft sensing lift system. It probably would struggle with a 4 bottom pull type. The WD45 would pull 4 bottoms in most conditions.
Red Ranger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Ranger Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2011 at 12:20am
Oh yeah, it'll handle it, Dad's ol '58 D17 with the original 4-226 had 4 btms hung on it for years, 3rd gear, high range, it would just snort and go.
Also those 18.4s won't make a difference with 16" btms., plowin' in high 3rd, you'll be throwing plenty of dirt to fill in what they'd mash down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2011 at 6:57pm
You must have had a lot of sandy and flat ground to easily pull 4 bottoms in high third??
Tim-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim-tn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2011 at 7:42pm
Hey Dr. been trying to send you a PM, says you have reached your max.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2011 at 10:12pm
Well, I now just deleted 40 messages......so give it a try.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2011 at 10:14pm
Dr, Time for a secretary??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2011 at 10:15pm
Maybe.....or maybe I just need to be smarter than the device I'm trying to operate??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Ranger Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 12:27am
Not at all, but here in lovely So. Ill. clay country we only have from 5-7" of topsoil in alot of places, so there's really no point in trying to go deeper.
As far as the hills, yes they did pull hard, but due to past erosion, rather than pull the power director back to low, and plow deep, which would only roll up clay, we'd just set the traction booster to raise the plow enough to keep going a decent speed, and still roll the topsoil over.
In those days (early to mid '60's) 17's were probably the single most popular tractor in our area, only outnumbered by IH's,  I could name 5 or 6 within 2 mi. of the home place, and every one, that  I know of pulled the same plow, same gear for "stubble/stalk ground", the only time we plowed a whole field in 2nd high was hard packed clover ground.
FWIW we haven't had a moldboard hooked to one of our tractors for over 20 years.
Edited by Red Ranger - 08 Mar 2011 at 12:35am
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 5:28am
The hp engine rating of a 230 g was 76 at 2300 rpm in a AII Gleaner.
This page was generated in 0.099 seconds.
