D17 Oil Leak
HansNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HansNE Quote  Post ReplyReply Direct Link To This Post Topic: D17 Oil Leak
    Posted: 27 Feb 2011 at 11:17am
My d17 has an oil leak on the underside, up by the pulley that runs the fan.  I'm not a mechanic and am guessing this is a bad seal.  What all is involved in replacing the seal, if that is the problem.  Thanks for any advice or tips.  Hans
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 11:31am
Start with your oil pan gasket.  It's best to pull out the front axle out from under it.  With all of that black stuff under there, you might find more gaskets that need replacing.
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 1:24pm
You have to pull the front end to remove the crank pulley. The crank gets grooved were the front seal goes so you might want to invest in a speedi sleeve.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 1:32pm
Thats some milky looking oil drippin off the bolt heads. Is it that color in the engine?
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 1:41pm
I start with a good cleaning as it's hard to tell right now.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
This page was generated in 0.266 seconds.
