Another Poll.....Media Blasting???
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Topic: Another Poll.....Media Blasting???
    Posted: 26 Feb 2011 at 8:59pm
So guys what type of media blasting do you use, if you use it, sand, glass, walnuts, plastic, aluminum oxide; and why?
Thanks!!
Still in use:
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 9:09pm
I don't like the left wing media. How's that for blasting? LOL!
E7018 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote E7018 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 9:12pm
The black sl*g stuff. It says  black diamond on the bags. 20/40 size works for my nozzle.
Getting water out of the air is the tough part for me. Finally, figured it out, for the most part.
Edited by E7018 - 26 Feb 2011 at 9:13pm
amac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amac Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 9:19pm
I like sand. Its cheap and most available. although something less aggresive works better on sheet metal especially blasting decals off. Sand used the second time works for sheet metal and its free.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 9:23pm
Well neither do I, but that's off topic :)
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 9:33pm
I thought this was going to be a political post too. Only thing I have used here at home is silica sand. I did see a set-up once that had an old window screen attached to a Briggs crankshaft that was run by electric motor. The guy would dig sand up at the public beach and sift it through the screen. Pretty cheap way to go.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 10:38pm
Black Diamond, bought two more bags today.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 10:45pm
sugar sand is my choice.very fine and feeds good in my blaster.also can use lower air press.on thinner metals
farmer0_1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer0_1 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 12:45am
for cast and thick sheet metal i get mason sand.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 7:38am
See If I am thinking correctly.  From my research I can go cheap on the heavy duty parts, with regular old sand blasting.  But anything sheetmetal, I should go with a plastic media of sime kind, since I am not a blasting expert and would tear up or warp sheetmetel with sand.
Sound about right?
Edited by Orange Blood - 27 Feb 2011 at 7:39am
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 7:43am
How long will 50lbs last, do you reclaim it as well, if so how many times before it is worthless?  What equipment do you use to reclaim it if you do?
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer0_1 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 1:27pm
when i did my M int years ago there was a local guy who charged me a couple hundred to do every part . couldn't beat that .  now i did my avery five years ago and i used a adapter on my pressure washer so i could use sand.  less to no dust. reclaimed the sand let it dry out and used it on the next project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 1:45pm
Lay down a big tarp to catch most of it.  After blasting dump tarp contents onto a bucket.  Use a piece of screen wire to screen the big bits and dirt out of it then reuse it.  You can use it several times before dumping it all and replacing with all new.
1968 one-seventy
1956 F40 Ferguson
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 2:06pm
Most older tractor sheetmetal wont warp with sand or coal sl*g, ie black diamond. But any thin sheetmetal will warp from the heat. I use walnut shells whenever there is no rust, more $, but less chance of wrecking trans and motor with it. What ever you use make sure you tape, and double tape around shifter boots, etc. The coal sl*g is more expensive than sand but i a lot more aggressive, so you get done faster. I do like the others said put dowmn a tarp and reclaim what you can and sift it. I made a wooden frame with some 2x4 and stapled some window screen on it and it works great And if you dont have a pressure feed sandblaster, then I would take it and have it done.
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
Bob-Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 2:26pm
I'm with Stan and Brian. I use Black Diamomd, put down a tarp and sweep it up. Run it through a piece of window screen and back into the blaster. Bob@allisdowneast
I used to think I was indecisive, but now I'm not sure.
Kraig (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kraig (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 3:41pm
Just be careful regardless of what media you use. A lot of the old paint is lead based paint so keep kids away and try not to inhale the dust. Also, silica can cause lung cancer. So be safe.
7010,D17D,WD45,WD,WC,WC,B,
Gleaner K,60,66,72
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 3:51pm
I have a little portable suction blaster.   I use sand, the white play sand from ToysRUs works great in it, it's much finer than regular sand and cheap at about $5 for a 50 lb bag compared to $20 to $30 for official blasting media.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 4:30pm
Darn, that's all?  I thought everything caused cancer.  I mean eggs, meat, potatoes, water, soap, they all cause cancer right?  That's what michelle obama said anyway?!?!  :-)
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote E7018 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 7:09pm
The place I get black diamond stuff from is about $7-8 per 60 - 80 pound bag. A commercial construction supply place.
Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 7:20pm
Is anyone familiar with soda blasting? I read somewhere that it works really well without the negatives that some of the other media cause.
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 7:31pm
  I use Black Beauty now, the brick supply house quit selling silica and sl*g, and when I asked where do I buy it they just srugged their shoulders.  I did find another place get a pallet a year, but 80# bags which I can handle a LOT easier.  One thing I have noticed when blasting hoods is that they will flatten out until you blast to other side, as far as warpage don't get too close and keep MOVING!
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer0_1 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 9:33pm
i went over to a soda blaster that has a business not to far from me and looked at his work and it did very nice.  he was blasting an aluminum boat and it wasn't warping i looked for bulges.  now any media will warp metal from my understanding. this fellow wanted $750 to soda blast my 85 suburban i am restoring. that included door jambs and me pulling all the stuff off. i am told it won't hurt glass either. i decided to grab my sandpaper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 11:49pm
Farmer; Not all media will warp metal. The reason we use walnut shells, crushed corn, soda, plastic, etc is that it doesn't build heat when you blast it, but it wont remove rust. Sand, glass, and coal sl*g generate heat when blasted, and that is what warps the metal. If that burb is rust free, then you sure would save a lot of time having him blast it. So much nicer working with clean bare metal when you are doing a resto.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer0_1 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 12:07am
i agree the heat build up is what causes issues .  so far from what i understand is that the dry ice blasters were the only one that will not make heat.  now i will be the first one to admitt i have only used sand.  i believe that the other media you speak of in the right hands will be fine.   if i knew with little experience i could use soda and not warp the big flat panels on a 80s chev i would.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 12:28pm
My buddy has his 70 Cuda completely soda blasted. The metal on your truck is a whole lot better than a 70s Mopar. If you are going to do soda yourself then I think you need a soda pot, as the regular sandblasting pots will not work. The guy around here that does soda, does all kinds of complete cars. If you done it yourself with walnut shells, then you would need about 15 bags, @ $25 a bag, and can be used in a regular blasting pot. That is what it costs in Ontario. You might be able to dicker a little bit and get the price down on the soda blasting guy.
Rogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 6:27pm
I have used Black Diamond and fine blasing sand. I prefer sand sand simply because I had less trouble with it stopping up. It is also cheaper. The main thing is having something that doesn't stop up the nozzel. Having enough air for the job and keeping good nozzels in the blaser goes a long way in preventing clogs. That  is my two cents and I have change to boot. LOL..
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
Gordy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gordy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 7:01pm
I use sand but I use spray can type  paint remover first then the pressure washer takes most of the paint off just need to sand blast the rust what little paint is left.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 7:37am
I use Black Beauty Fine in both my pressure blaster and my Blast Cabinet.  Pot blaster is ALC from Caqrquest, nice blaster. Cabinet is a Skat-Blast from TP tools.
1968 D15D,1962 D19D
Reeseholler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 6:35pm
I used 50 lb bags of quick crete play sand for my CA. I did all of the tin by hand except the fenders. All of the cast stuff that I took off I blasted. for 2.50 a bag, it saved me a lot of wire brushing and sanding
This page was generated in 0.330 seconds.
