Putting Weights on D17
allis restorer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis restorer Quote  Post ReplyReply Direct Link To This Post Topic: Putting Weights on D17
    Posted: 24 Feb 2011 at 4:10pm
I was wondering if i need to add weight on the front of my D17 for plowing, im planning on pulling 3 14's in really rocky ground. I am makeing a bracket on the front and im wondering if i should make it so i can add weight or if i dont need too. thanks steve
Go orange or Go home!!
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 4:24pm
Add a rock box to the front , add weight as you need it, much cheaper than buying front wheel weights. A d17 in anything other than sticky clay should sing pulling 3-14's, you may not need any additional weight on the front.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 4:30pm
Go slow when plowing in rocky ground! If you are moving quickly ans a share goes under a large rock, the front end of the tractor can come off the ground VERY quickly. Ask me how I know this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis restorer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 4:42pm
i have an allis chalmers 3 bottom trailer plow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 5:24pm
Pull type 3-14's??? no front weights needed.
D17JIM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2011 at 12:12pm
Pull type no front weights but weight the back.  We used to run 300 lbs in each wheel with fluid on pull type oplows on D17's and WD 45. Clay ground.  Jim
