WC clutch lock?
abbaschild95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote abbaschild95 Quote  Post ReplyReply Direct Link To This Post Topic: WC clutch lock?
    Posted: 22 Feb 2011 at 11:19pm
im just curious as to why there is a lock on the clutch on my WC?? anyone know the reasoning?
Great-granfather's WC---- hopefully many more to come!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 11:36pm
1. It is a safety device to be used when crank starting the tractor.
2. If you store the tractor for long periods of time, the clutch can be locked out so it won't "freeze" to the flywheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote abbaschild95 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 11:46pm
ohhh ok great thanks!
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 7:18am
Also easier cranking/starting in cold weather.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 7:59am
Also to engage the belt pulley while the motor is running and to stop belt driven equipment while the motor is running.
