M Crawler grill guard
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Topic: M Crawler grill guard
    Posted: 22 Feb 2011 at 9:55am
Can anyone tell me if this is a factory mount for this guard? My parts book does not show it. I'm also looking for a straight guard like the one in the picture, if there is such a thing! Thanks for any input.
Edited by Chad(WI) - 22 Feb 2011 at 11:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 9:59am
Totally unrelated to the post.....but can anyone tell me why I can see the images in the preview section to the post, but I get this mess when I actually post it? I've had this happen quite a bit.....I'll try to clean up this later.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 2:49pm
Hope these work.....
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 3:21pm
Mine bolts on directly to the tanks so it sits closer to the radiator, if you took your bracket off and moved the gaurd straight back that's what mine is like. Who nows which is correct, maybe both.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 3:25pm
In my M parts book there is no picture but the radiator gaurd group comes with 1-gaurd and 4- 5/16x1-1/2" bolts which it says would replace the tank bolts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 3:48pm
Thanks Lonnie....these monting brackets look almost to good to not be factory. Wonder what the advantage is to the extra distance from guard to radiator?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 4:08pm
I think I know the answer. Yours does look too good to be not original so I looked in a newer parts book and it lists radiator curtain assembly and calls for rods which you have on yours and I don't on mine so the bracket moves the gaurd out and gives a place to install the vertical rods for the curtain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 4:23pm
That makes sense now just by looking at it....thanks again for the reply.
This page was generated in 0.539 seconds.
