All-Crop 90
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: All-Crop 90
    Posted: 22 Feb 2011 at 8:01am
Seen something odd the other day on an all-crop 90. Kinda hard to explain, but some of these 90's had the "hump back" on the part of the seperator directly behind the cylinder.
At this area is also a step out on the seperator back wall. With the use of some tines in the seperator, the straw and grain was thrown against these tines but the grain would pass thru the tines into the step out chamber. This grain would  fall down the chamber directly on to the grain drag floor to be taken directly to the cleaning shoe.
Well on this machine the step out chamber was blocked off by sheet metal, making it useless. The sheet metal looks factory as there is still some paint on it...
Explanation?
Edited by TomYaz - 22 Feb 2011 at 8:02am
Bull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bull Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 8:57am
Just a guess but may have been something they did to add capacity for a corn head and left the block off plate in unless you did have the corn head attached.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 9:44am
plate was used depending on what the crop harvested was I believe.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 10:11am
Maybe thats it. Will have to look into the operators manual on the next bunch I buy.
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 11:36am
The 40's (late models) are that way too.  Somehow I thought that the 60/66 had the cylinder grate cover plate as well, but I am often confused.
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 9:08pm
     The deflector and comb
         The straw and threshed seed leave the cylinder and contact the combs where some some seed is permitted to go through and fall into the grain discharge and onto the grain drag and straw onto the straw rack.
        When threshing clover and other small seeds the grain discharge cover should be installed.
        The grain discharge cover should also be installed when threshing dry chaffy, brittle straw which would go through the combs, fall into the grain discharge and overload the cleaning shoe.
                                         Page 21 operators instructions
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 9:25pm
what you saw was a peanut special.a friend of mine in fredricksburg texas has one for sale...250.00
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 9:32pm
Thanks Harold...learn something every day!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 6:52am
I'll have to look to see if my 90 has it. I know it has the combs.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 7:00am
These are the best pictures of that area I have on hand. Sereial #5913
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 6:05am
On the one I looked at, the rounded metal shown here isnt there...that looks odd..seems to me that would block the grain from emptying out of that step back and cause it to pile up behind it, or am I interpreting the picture wrong?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 6:20am
I'll have to get down to Dad's (that's where it's stored) and take a closer look for myself.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 6:53am
Ok...but anyway, that step back area behind that round piece is blocked off by a piece of sheet metal, I guess for certain seeds/straw conditions per the operators manual mentioned here....
Matt Z Gracy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Z Gracy Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 8:55am
Do you have a number for this person. I have  90 already but would buy another one for a spare  I have a ranch 40 miles from Fredrickburg Tx
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 7:43pm
matt...appreciate your reply but joe graunke out of wisconsin got together with mr.staudt and brought it.that is the only 90 i can remember we started out with a 60 in 48-49 and ended up with a 72 before going self propelled.matt do you go to the fredricksburg show in june?its an 8 hr. pull for me,but my daughter and her husband live in boerne,so free lodging.its a 3 day event lots of old old engines there...
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 7:44pm
Wasnt for sale...
ICTRCTR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ICTRCTR Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 8:01pm
  Parts book lists this as a discharge door after serial #601 & up. before that it shows just a flat back an the model 90 all crop.   thanks.
This page was generated in 0.539 seconds.
