getting grease out of the brake housing
Tim in arkansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim in arkansas Quote  Post ReplyReply Direct Link To This Post Topic: getting grease out of the brake housing
    Posted: 20 Feb 2011 at 7:47pm
I took the brakes out of the 1940 Allis B today it has a lot of grease and crap in it  is there something that can be used to get all the crap out  I am using a long handle screwdriver to get what I can see out  any ideas?   thanks Tim
Allis Chalmers fan from Arkansas
MBolton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBolton Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 9:47am
Just keep digging and scraping then wash it out with some solvent, let dry and put her back together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 10:04am
Support the rear of the tractor and remove one rear wheel. Now remove the final drive housing and clean things up. Replace the seals in the differential where the shaft comes out and the seal in the final where the shaft goes in. Leaking seals is where the grease comes form. Brakes are marginal when new, you don't need lubricant on them as soon as you replace them. JMO Charlie
Edited by CTuckerNWIL - 21 Feb 2011 at 10:06am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 10:06am
I used an 'engine cleaning' gun. Basically an air gun with suction feed for fluid. It'll suck up 'gunk' or other degreaser, and press of a button, you get a good blast to smash the grease down into liquid! You MUST wear glasses, maybe drape the openings and use a big tray underneath to get the liquid sludge.
It's one of those ,'use it once in a blue moon tools'..also good for spraying cherry tress with dormant oil spray.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 6:13pm
I used Gunk brand spray on engine degreaser on the bell housing of my D17D that had a severe rear main oil leak. I used my power washer to spray it off. Worked very well.
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 6:21pm
removing the whole final drive assembly (4 bolts) saves you a lot of effort and really is the way to go.  Like they say it lets you look everything over and replace seals...
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 8:52am
I always replace the entire band, and do not re-use it. So I can take the old band, and cut off the loop section from one side.  Now you have a custom-made, custom-curved scraper.  Wedge that sucker in there, and pull it out with a nice clod of goo.  Repeat until the old band will pass all the way through with no resistance.  Then use brake parts cleaner to dry everything out.
Reinstall band.  The above posts to have a valid point that you need to resolve where the oil came from.   My experience, is that it is such a tiny leak, my customers just want the brakes fixed and the access hole cleaned out.  Rats and mud-dobbers plug every hole around here.
JimD
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 9:31am
Never reuse an old brake band???
Then you go from a 30 dollar parts cost to close to or over a 100 dollar parts cost.
Not from my pocket book!  Ain't that hard to pull loops and all if you go about the right way. I have been able to reline most bands. Some are rusted in the henge to where they can't be reused but you sure can not make that judgment after cutting off one end.
If you pull the final drive you can pull the brake band  off the drum and out the opening rather than pulling it us thru the top.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 9:51am
Dick, I think you msunderstood me.  I cut the loop off after pulling the band.  Out of 20 or so jobs I've one, I think I had 1 band that was usable enough to have my name on it.  All the others had rusted at the hinge since the drain was plugged, or the adjusting bolt was damaged.
Don't forget that my customers have to pay me for my time to rivet the new pads back on.  1 hr to clean and rivit the pads back on (both sets) makes those $30 pads now $80.  Or at $45/side $90 gets you new bands with adjusting bolts.  I sell plenty each way.  And I refund quite a few pads when the customer gets their band out and realizes they are shot.  So they end up paying frieght (though it's not much) for the pads 2 times and then buy the bands anyway.
As for pulling them, I use a come-along to ratchet them out.  Usualy grabs 1/2 the junk onthe way out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 12:28pm
Ya I misunderstood about that! I thought it was asking on how to do it his own self. I have pulled a few bands out the top and also have taken a few out thru the transmission end of the final drive after it was removed.  With it removed you can really get it clean and the new band can go back in when your done sooo much easier.
I love clean when it comes to parts. You wouldn't think I loved clean if you got a look at my Carharts.
This page was generated in 0.110 seconds.
