G cultivator pins
Italy Hill Produce View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Italy Hill Produce Quote  Post ReplyReply Direct Link To This Post Topic: G cultivator pins
    Posted: 20 Feb 2011 at 8:57am
Hey I need a set of the pins that hold the cultivator to the scissors lift (or whatever you call it) Can those be purchased new? Or is there someone that has a bunch in a pile in the barn somewhere that would part with two?
Thanks
Jonathan
G tractor and an All Crop 66
Also Kubota MX5100F and M9540HD12
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 9:07am
I don't know if they are available new or repro but here is something that will work if you get the right size. http://www.shoplet.com/Jacobs-chuck-Morse-Taper-Ejecting-Drifts-30485/SEPTLS40330485/spdv  There are several different size Morse taper ejecting drifts.
The part number you want is the same as the CA front mount cultivator bracket uses if that is any help.
LannyMTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LannyMTN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 11:01am
Can  someone tell me if the wedge pins are the same on the CA cultivator, 80r mower, and G cultivator? If they are I can possibly find a pair.
Lanny Mid TN
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 11:03am
Lanny, I understand they are the same. I believe the Turners who help throw the G Roundup reproduce them
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Italy Hill Produce Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 11:37am
Let me know.. They are the last pieces to the G cultivator puzzle I've been putting together...
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 1:08pm
I made a couple for my cultivator last year.  I think it was Joe M GA sent me the measurements.  Pretty easy to make and they work fine. Used 3/8" plate.  Didn't get the little chain thingys made for them yet though.
I can send you a drawing if you want - can't seem to get a pdf to post and can't finger out how to convert it to a jpeg.
Cheers,
Creek
Edited by Creek Jenkins - 20 Feb 2011 at 1:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Italy Hill Produce Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 5:16pm
I already have two, on my other G, I just figured if I could buy two of them (they appear to be hardened) then I wouldn't spend a couple hours screwing around making them... Ie I'd rather spend the $20 for the correct part, then run to town, get some metal, and then spend 2-3 hours screwing around cutting and grinding etc.. Yes it should not take that long, but by the time I get the material, get to the shop, get the shop warmed up, make them, then get the shop cleaned up etc.. I just wasted half a day when I could have paid someone the $20 for the correct part...
Post Options Post Options   Thanks (0) Thanks(0)   Quote LannyMTN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 3:30pm
Jonathon,
I looked for those pins and wasn't able to find them. Sorry about any delay I may have caused. Lanny Mid TN
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 5:06pm
uploads/1014/Cultivator_Pin_A.pdf
See if this works - if you click on it it should take you to the drawing.  I hope.  Maybe.
