7060 engine
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Topic: 7060 engine
    Posted: 16 Feb 2011 at 7:06pm
neighbor has a 7060 with a bad engine, hole in block, does anyone know what it would take to put a 426 engine out of a combine in it?
Toscani NE SD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani NE SD Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 8:14pm
if your interested i have a 7580 engine with 750 hrs on overhaul i was going to use ,but i would sell it send a pm if interested
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 8:38pm
It's not a single day job, if thats what you are asking.  but it is fairly straight forward, just going to have a lot of work to do.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 9:15pm
Front mounting will have to be changed unless you weld brackets to mount to frame. Rear may or may not have to be replaced.
  Injection pump from combine may have electric shut off which can be changed or run wires for a switch.   MACK
