What the F%^* is this!?!?
JR Maley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR Maley Quote  Post ReplyReply Direct Link To This Post Topic: What the F%^* is this!?!?
    Posted: 15 Feb 2011 at 5:06pm
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 5:09pm
dunno...but everyone should have one!
Brad-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad-MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 5:11pm
That could be one of the coolest concoctions I have ever seen, a segue for AC nuts!
1930 U
1938 A
1941 WF
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR Maley Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 5:12pm
I hope somebody here may know the guy, and how it works.  I would drive that at every event I go to.  Look at the confused stares on the faces of everybody around him, its too funny.
Dean/MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean/MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 5:25pm
That's an Allis segway, way ahead of there time again!
HD16,917H,185,7050,8030FWA,8050FWA
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR Maley Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 5:33pm
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 5:41pm
there is 2 tires and wheels inside the tire not sure how it drive them
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 9:57pm
OK, I gotta figure out how that works!! Then I want one!!!! Think it would be even cooler with AG tires on it.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 7:17am
It's a Smokey Stover 2-wheel'd car.  Google it, you'll see pictures from the old cartoon.
Yes, there's actually four wheels... two in each tire.  Balance is slightly critical...
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 7:54am
Really not that hard to make. Start with a hydrostatic rear end from a garden tractor,add independent brakes on the axles Power can be 5-10 hp engine.On the bar that the guy is holding, have 2 bicycle brake levers for left and right turning(same as a crawler ?).
The 'trick' is to get the balance 'right'.
hmm...I've got two great 16" tractor tires/rims off a 2 wheel cultivator...and a 'spare'hydro unit in the shop......
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR Maley Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 8:03am
When the guy gets off does it tip forward and falls over?
NEJim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEJim Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 8:31am
I hope he doesn't gain weight......
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 1:05pm
Yeah, JR... sorta.  Notice that he's pretty close to the tires... well, the center of gravity needs to be directly above the 'apparent' axle.  Most of what's hanging out front is empty bodywork... engine is far back, and pretty low.  Usually, when guys build these, they can get 'em to balance... albeit barely... with them not on... and it's about right when they sit down.  There's oftentimes a kickstand of sorts that swings down when the op climbs off.
Embellem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Embellem Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 1:10pm
I had an old Popular Mechanics magazine that had plans on how to design a Smokey Stover car. But I can't seem to recall seeing it for a while after moving a few times. Plans are definitely out there for how to do it.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 9:53pm
That is one possibility------saw a clown car built like that.  However, that method normally requires the big tire to be running fairly soft to give room for a little distance for the 2 small wheels running inside each big tire.
The other possibility is a gyro located some where inside.
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 10:01pm
No gyro, and no 'soft' about it-  they're flat-  airless.  Imagine a tracked skid-steer...  rather than having tracks, it has an old, really big tire.  The tire is just there for looks- it's for the illusion.  The real 'wheels' are rollers about 6" diameter, sitting on an 'A' shaped bracket.
Yes, the "Foo Mobile" Smokey Stover Two-Wheeled Car was featured in June 1978 issue of Popular Mechanics, with a cutaway of the tire shown on Page 170.
You can see it here:
http://books.google.com/books?id=qc8DAAAAMBAJ&pg=PA118&lpg=PA118&dq=Smokey+Stover+2-wheel+Car&source=bl&ots=etyMV6-0H3&sig=xHyu_jzI7OlF17tPMW7f00fGIGA&hl=en&ei=yp1cTdusGIP88Ab4n5yuCQ&sa=X&oi=book_result&ct=result&resnum=3&ved=0CC0Q6AEwAg#v=onepage&q=Smokey%20Stover%202-wheel%20Car&f=false
(link should work if you cut-paste it)
The PM described setup, was two support wheels, and the RIM also rolled on a trio of rollers, with each wheel driven by a chain and hydraulic motor.  Other drive concepts I've seen, is where the support rollers each have a sprocket, and are both driven by a common chain going through sprockets on each roller... where the DRIVE sprocket comes in the middle of the axleshaft, and the tire is actually mounted to a 'fake' rim that's just along for the ride.
Edited by DaveKamp - 16 Feb 2011 at 10:09pm
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2011 at 7:08am
Friend of mine Don Hayes had one like that several years ago with a cab on it made to look like A mODEL T. I drove it in a parade somewhere in the summertime and boy was it HOT! Pretty neat, tho. He died several years ago and I dont know what happened to it. Lots of fun!
