lift housing on d17?
D17 owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17 owner Quote  Post ReplyReply Direct Link To This Post Topic: lift housing on d17?
    Posted: 14 Feb 2011 at 9:07pm
My ? is not really about the lift housing but the two bolt holes for the drawbar bracket. I took the housing off to check the spider gears and pinion gear. I also wanted to replace the o rings for the lift arms and the o ring in the lift arm cylinder. I see that the two bolt holes for the  drawbar bracket are in bad shape. Is this a common thing?  What would be the best way to fix it? drill next size bigger or use a heala coil?  Any info is great info. Eric
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2011 at 9:46pm
If you're talking the holes in the underside of the lift arm housing or tranny housing, I'm not there looking at it but, I'd probably prefer a good helicoil. If you go a larger diameter bolt (7/8") the head of it may be too large for the bracket to be able to tighten it with a socket????
This page was generated in 0.229 seconds.
