Carb install on UC?
ac_bowsers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_bowsers Quote  Post ReplyReply Direct Link To This Post Topic: Carb install on UC?
    Posted: 14 Feb 2011 at 8:35am
Been a while since its been off, trying to finish up restore, I put carb on lined up notch, but all it does is idle, do you have to have spring pressure against governor shaft or did I simply not get notch into wood bushing. Probably a dumb mistake any help out there thanks!!!
Pine Stock Farm "Home of the ALLIS" 35-WC-36-U-37-UC-47-C-49-G-57-D17-58-D17puller-63-D21-71-210puller-79-7045-83-8070-AA9675-BigTen-B10-310-1300fieldcult-snapcoupler imp.-longhopper blower,signs,etc.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2011 at 11:13am
Been in to alot of these just  a U last week .Where do you see a wooden bushing .There is a felt that is around the shaft that comes thrught the block ,for oil control .
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_bowsers Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2011 at 11:32am
the piece inside carb where shaft from block goes into
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2011 at 12:46pm
Brass !!!!
This page was generated in 0.115 seconds.
