Got my airplane tires all mounted up for my D17 |
ChuckLuedtkeSEWI
Joined: 11 Sep 2009 Location: Jackson, WI Points: 1826 |
Topic: Got my airplane tires all mounted up for my D17Posted: 13 Feb 2011 at 7:32pm |
Thought I would post some pictures of the tires that I bought from Gensco for the front of my D17 series 4 that I put a loader on. I was looking at getting some good 4 rib tires that had a good rating for weight etc, but they were close to 200 a pop. A week or two ago, there was a discussion about good loader tires:
Rawleigh suggested buying used aircraft tires from Gensco:
The ones that I got that are the same size as 9.5L-15 fronts were 55 bucks a piece plus shipping for used tires. They would have been 88 a piece for retreads but the guy told me that these would work just fine and after receiving them, I think they will. With two tires and shipping, it still cost less then 1 good new four rib tire, and these are 16 ply and are recommended for up to 45 psi and no faster then 25 mph. They are more like an implement tire in the grove pattern, but they are heavy duty tires The load rating on them as aircraft tires are 210 mph and are rated for 14500 lbs per tire. I think they'll be more then heavy enough!! Each tire shipped was 44 lbs.
Here is some pictures of them all mounted up to the rims that I got from my dad. I think these are going to work just fine. Thought I would do a writeup because these are some nice heavy duty tires and definately saved me a bunch of green compared to new ones. The salesguy that I talked to said that the rubber is a different composition and won't dryrot or crack over time. We'll have to see. Anyways, here are some pictures. I will post some when I finally get them mounted on the tractor
Brian G. NY
Posted: 13 Feb 2011 at 9:07pm |
Looks like a great deal!
Now, if the ribs on either side of the center rib could somehow be
ground or cut out, you would have something similar to a tri-rib.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90778 |
Posted: 13 Feb 2011 at 10:06pm |
Looks like the deal of the day... Nice looking tires !
JohnCO
Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Posted: 13 Feb 2011 at 10:09pm |
Were they hard to mount?
Allis Express participant |
TexasAllis
Posted: 14 Feb 2011 at 7:03am |
Aircraft tires are better in every respect over auto and implement tires. Even used you have a better tire.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25239 |
Posted: 14 Feb 2011 at 7:05am |
Just keep the nose up of your B-17, wr D-17 when landing !!
Great score !!
Eric[IL]
Posted: 14 Feb 2011 at 7:15am |
Smart move. 16ply - wow! Thanks for sharing..
Brad(WI)
Posted: 14 Feb 2011 at 7:19am |
We've used them for years on our mixer wagon. They are 20+ ply in that size, and when they go flat, you may not notice til you get a load on it. We buy them with the split rim, bolted together in the middle. When they do go flat, the tire guy is not happy. Very hard to deal with that many plys in the sidewalls. Should last you forever in your application.
john(MI)
Posted: 14 Feb 2011 at 8:00am |
Just remember what the Military Air Traffic controllers always say; "Flaps down, Gear down?"
Tires look good! I will definately remember them when I get to the point with my D14!
E7018
Posted: 14 Feb 2011 at 8:20am |
I did break a spindle on a D17 series 1 narrow front. So, still use common sense as to what you do with the loader.
SHAMELESS
Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
Posted: 14 Feb 2011 at 9:14am |
ok...sooooo...how long would they last ona car? lol (summer only)
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6118 |
Posted: 14 Feb 2011 at 11:43am |
Wow... on a car... that'd be HEAVY... better put some 13.8x26's full'a fluid on the rear if you're gonna run in traffic! (yeah, you'll hafta open up the fenders a bit)
randy
Joined: 12 Sep 2009 Location: Illinois Points: 1260 |
Posted: 14 Feb 2011 at 12:20pm |
I put 12 tires on my wagons. New firestones were $300. plus. Replaced 16.1 x 16 from Gensco for $160 freight included. Not much of a choice!
Byron WC in SW Wi
Joined: 11 Sep 2009 Location: Wisconsin Points: 1635 |
Posted: 14 Feb 2011 at 1:14pm |
What a great idea. Looks like they'd be great implement tires and I need them now and again.
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 14 Feb 2011 at 1:51pm |
My grandfather, used to run airplane tires on the grain cart/auger wagon. The stalks would desroy regular tires in a couple of years, but after the first two years, he put on only two sets of airplane tires on for the last 20+ years he used it. I remember when I was a little kid riding with him, and looking back seeing the sidewall of the tires looking like the bottom of kids jeams today, and thinking those are going to blow. I don't know what he bought them off of, but they were around 4' to 4'- 6" tall and about 2' wide, I am guessing a big Boeing of some kind.
Still in use:
HD7 WC C CA WD 2-WD45 WD45LP WD45D D14 3-D17 D17LP 2-D19D D19LP 190XTD 190XTLP 720 D21 220 7020 7030 7040 7045 3-7060 Projects: 3-U UC 2-G 2-B 2-C CA 7-WC RC WDLP WF D14 D21 210 7045 N7 |
Jim-Tea
Posted: 14 Feb 2011 at 2:42pm |
What did you use for rims ?
Rawleigh
Joined: 14 Sep 2009 Location: White Stone, VA Points: 421 |
Posted: 14 Feb 2011 at 2:59pm |
Genesco has great deals on rims too. You can buy them already mounted. Glad they are working out for you Chuck!!
LionelinKY
Joined: 12 Sep 2009 Location: Radcliff,KY Points: 699 |
Posted: 14 Feb 2011 at 3:00pm |
I remember growing up on the farm in the 1970s, Grandpa was always a fan of wider tires to reduce soil compaction. We ran a JD 54 spreader from before I could remember right up to when we sold the farm in 1989. Dad replaced the tailgate and beater at least once that I know of but the big old airplane tires that Grandpa had put on it lasted its whole life. They were at least 3' tall and at least 18" wide. Tread never seemed to wear down. Still had tread when spreader finally went to scrap. The sidewalls were rubbed down to cord in spots from us backing under the barn cleaner chute and rubbing the massive wood beams which supported the cleaner. I don't recall ever having the tire truck there to service them which definitely would have been required.
ChuckLuedtkeSEWI
Posted: 14 Feb 2011 at 6:29pm |
Thanks for all the replies. These tires weren't the hardest to mount, but you can tell that there's alot of plies in the sidewalls. I used my brother's tire changer at his shop to mount them. The first tire, after I got the first half mounted and the tube in, when I got the other half mounted the tube stem popped back in the tire. Boy did I fight the tire sidewall down enough to get the tube stem back up in the hole. I didn't have my tube stem keeper thingamajig with me, so on the second one, I used a small visegrips to hold onto it, until I aired it up. The rims were some implement rims I got from my dad from a running gear that we scrapped out. By no means did they look this nice when I got them, but I sandblasted them down to bare metal and repainted them. I did have to touch them up after mounting the tires. There is a little rust pitting on them from before but for what I am using them for they are good enough, and plenty strong yet.
allischalmerguy
Joined: 11 Sep 2009 Location: Deep River, IA Points: 2895 |
Posted: 14 Feb 2011 at 6:32pm |
Looks like another good application would be trailer tires. I had to buy some expensive 150.00 chinese tires for my trailer that I haul my tractor on. These things look like they would of worked wonderful for that application too!
Mike in Iowa |
NickT(Ky)
Joined: 13 Sep 2009 Location: Elizabethtown, Points: 417 |
Posted: 14 Feb 2011 at 6:54pm |
Alot of guys around here use those tires mounted on the heavy-duty rims that come with them on the large round bale wagons. You know the ones with the narrow fronts. They trail real good too.
TexasAllis
Posted: 15 Feb 2011 at 7:35am |
Buddy of mine has some mounted on a 16' trailer he uses to haul fuel with 300 gal tank I think. Pulls down the road real nice.
bobkyllo
Joined: 14 Sep 2009 Location: minnesota Points: 1568 |
Posted: 15 Feb 2011 at 7:53pm |
they are not bad to work with if you have the split rims. but putting them on a regular rim sucks.
Claus
Joined: 09 Dec 2009 Location: Hebron In Points: 1166 |
Posted: 15 Feb 2011 at 8:01pm |
Need pics of them on the tractor to do them justice!
RGR(TX)
Posted: 16 Feb 2011 at 7:05pm |
THEY ARE ALL MARKED OFF ROAD ONLY 25 MPH MAX
Eldon (WA)
Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Posted: 16 Feb 2011 at 8:01pm |
I think most of the stack movers use them too. Chuck, when are we going to get a pic of the tractor?
ALLIS EXPRESS!
This year: |
ChuckLuedtkeSEWI
Posted: 16 Feb 2011 at 9:00pm |
Eldon, hopefully I will get some time this weekend, but it's muddy like crazy here and I have a birthday party here for one of the little ones on Saturday, so if I rutt up the yard, I'll be in the doghouse. Maybe by Sunday afternoon. You should recognize at least one set of tires in the picture!!
