190xt
tx091 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tx091 Quote  Post ReplyReply Direct Link To This Post Topic: 190xt
    Posted: 13 Feb 2011 at 9:38am
Thge 190xt gas I use for Snowblowing starts hard, it fires but babbles around until it has a mind to start hitting on all 6. Then it is fine. If it is plugged in it also is fine. Appears now i have fouled a plug and will replace. Recently replace the cap, wires, points and condenser. I also run Heat in the winter to avoid freez up. Any ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2011 at 12:33pm
Sounds like a typical 90 HP gas tractor to me.....hand on the choke knob for the first 10 or 15 minutes and then once warmed up OK fine.
49WF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 49WF Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2011 at 1:04pm
 I just came in from installing a pertronix conversion kit to electronic in the distributor. The old girl runs smooth now, shaft has to much play and it was hard to keep a good point gap.
More than I need
Josh(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2011 at 11:03pm
I had the same problem. Started adding octane booster to it instead of heat, problem solved.
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2011 at 12:24am
how far back...age of tractor wise, can a person put that electronic ign on? do they have kits for all gassers?
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2011 at 6:42am
I see them advertised for the WD and WD45 all the time, I imagine the 190 should have one out there somewhere.
Edited by Orange Blood - 14 Feb 2011 at 6:42am
Still in use:
49WF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 49WF Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2011 at 9:27am
Shameless, you can go to Pertronix web page and look up for tractor or distributor number .
More than I need
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2011 at 9:42am
Dad's old XT gas was always a good starter in the cold. Never had a block heater until the mid 1990's but when it was real cold he used to cover it with a canvas and used a knipco heater to warm it up while we milked the cows just because he thought it was too hard on it to start when it was -20˚. Used it just to move round bales to be fed until I bought the D19 with an aftermarket 3-point.
Wink
I am a Russian Bot
