valves
Joel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joel Quote  Post ReplyReply Direct Link To This Post Topic: valves
    Posted: 08 Feb 2011 at 7:38pm
I thought i was doing something good, i set out to adjust the valves on my wd45, is there a proper procedure in doing this? For there is multiple "F" marks on the flywheel, which one do you use? Please help!!!
thanks joel
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 7:49pm
  i set mine cold.011take  off plug wires  when numb er one fires then set that cyl. an so on  has always worked for us
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 8:01pm
Dont worry about the firing Just adjust one cylinder at a time and here is the correct procedure to get it right  on any engine with a solid lift cam shaft. For proper adjustment  you have to adjust the intake valve when the exhaust valve starts to open . then set the exhaust lash when the intake valve is pushed all the way open and just starts to close.
This page was generated in 0.332 seconds.
