190 XT questions
Dwayne TX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dwayne TX Quote  Post ReplyReply Direct Link To This Post Topic: 190 XT questions
    Posted: 07 Feb 2011 at 11:42pm
First, how do you access the linkages for the throttle, hydraulics, etc?  Is it the one panel in the center or does the front come off?
And, how big a project is it to replace the seals behind the lift arms on the splined shaft?  It's developed a pretty good leak, so I need to fix it quick.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 9:34am
There is a access panel on the inside of the console about where the seat is.  Not a lot of room but thats all ya get.      There is a snap ring on the outside of each lift arm, take off the snap ring, the arm slides on a splined shaft.  After the arm is off slide the shaft thru the housing a ways to get to the oring oil seal.  If your bushings are worn  replaceing orings probably wont fix it.  Also check to make sure the oil level isnt to high in the rear end.  Good luck.
AndrewGubbels View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndrewGubbels Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 7:15pm
skip you are dead on!!  it is just not an easy task.
andrew
Andrew Gubbels
Gubbels Restoration
This page was generated in 0.131 seconds.
