Popping noise in WD rear wheels
JohnThomas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnThomas Quote  Post ReplyReply Direct Link To This Post Topic: Popping noise in WD rear wheels
    Posted: 07 Feb 2011 at 7:31am
I am hearing these noises as the WD rear wheels get a sudden grip after slipping or as one wheel rides up on snow bank as I am using back blade. The popping is continous as the strain is on them. No popping if just traveling along. Sometimes popping  when I  reverse.
I can't see any movement in the hub lugs..they very tight...no movement observed in the
stops on the adjustable bars.
Tires are new and I have lowered the pressure for grip and bulged just a bit on ground.
No fluid. I've crawled all around these tires looking for some sign of slip..no luck...
What's causing this?????
Thanks!
Life is short...Make haste to be kind
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2011 at 7:36am
It could just be the snap coupler making noise as the impliment (blade in this case) moves around under varing load.  My WD-45 will make noises sometimes when pulling a 12' disk, quite a load.  Hopefully that is all you are hearing, I am sure you know what the other option is?  i.e. bad wheel bearing, missing teeth in the gearbox somewhere, e.t.c
Still in use:
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2011 at 7:46am
Sideways motion on the power adjust rails.  Never had the problem on the 45 until I changed the width to transport on a trailer.  Made the same sound ever since.  Doesn't hurt anything, but very unnerving till you find out what it is.
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2011 at 7:57am
I have this same popping since putting new tires and rims on my 185. -- and yes it is very unnerving. Have been concerned that it might be an unsafe conditon. Only does it under load and wheel on downhill side.
KC-WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC-WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2011 at 8:03am
I'm with Dave. Have you recently changed the width on the rear end? I changed mine for transport and then went to plowing this fall and my right wheel started making a loud popping noise when I would hit a tough spot. I loosened everything up and repositioned the wheel and then tightened it down and it went away. I think the ecentrics and the rails get worn or the wheel gets unevenly bound sometimes or at least in my case it was.
Steve Wilkens View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Wilkens Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2011 at 8:29am
MY WD does it now, and have had others do it as well, the noise is coming from the rails. I rechecked everything, and have come to believe that it has to do with wear and there being a little bit of slop in the ecentrics. Hasn't caused any harm that I am aware of.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2011 at 9:56am
Not too long ago I know you could get the half moon wedges from AGCO that fit in the eccentrics. If the rails are worn I would think you can build them up.
Wink
I am a Russian Bot
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2011 at 10:09am
The ecentrics are not tightening down against the rail.  May be the wedge or the rail is worn.  On the 185 which doesnt use a wedge, the rail or clamp is worn.   Look for worn spots on the rail, sometimes the wheel can get a little out of round too.     Ive take them apart and built up the wedges and the rail where is it worn to fix it.    the popping can get awfully loud, make me nevous as I dont want if coming apart.   HTH
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2011 at 10:56am
When I changed the width on a WD I had once, I was surprised when I spun the wheels that pieces of hack saw blade fell out.  The previous owner had apparently dealt with the slop/rattle by shimming it with pieces of a hack saw blade.  It seemed to work fine.  Not factory correct, but apparently got the job done.  Make sure the locks/stops are in place in case it comes loose and tries to spin when you hit a hard pull.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2011 at 11:09am
Yep, eccentrics.  Happened to me too on my CA when I got new rims.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnThomas Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2011 at 11:53am
Well Thanks Guys....I got a few old hacksaw blades...should last till spring..too much snow and too cold to be doing rail buildup  now.
I had a hunch that was it but got pretty worried abt it this last time cos I was into some 2-1/2 to 3  feet deep snow...it did it a lot!
Thanks again....
dudley wallace View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dudley wallace Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2011 at 1:49pm
mayby the wedges where they tighten up are wore a little bit they can be replaced with new ones this wedge is between the bolt and the rail.
a member of hendricks county antique tractor and machinery association club.
papastanh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote papastanh Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2011 at 9:50pm
John, I haven't had my D-14 for very long and have only a chance to drive it for a short time. It has not been driven for at least six/seven year (in a barn), but it too makes noise in reverse and when first starting out in forward motion. Thanks for bringing this item up on the Forum. I will check out the tips given. Is your noise since been corrected? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnThomas Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 6:35am
No chance Papa ... to work on the wheel..been pretty busy here tho with Allis..
Arm pit high snow takes awhile with just a back blade. It sure did a LOT of popping yesterday!!!
Edited by JohnThomas - 11 Feb 2011 at 6:37am
Gary (sw Wis.) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary (sw Wis.) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 7:51am
I used metal banding between the eccentrics and the rail about five years ago. Still working just fine.
190XT - D17 - D14 - WD45 w/loader - WD - (2)B110 - 616H - 610 - B-208 - WD with 190 Mounted Corn Picker - All Crop 60
This page was generated in 0.438 seconds.
