found this on you tube |
ToddSin NY
Joined: 08 Nov 2009 Location: Newark,NY Points: 1034 |
Topic: found this on you tubePosted: 06 Feb 2011 at 10:40pm |
Is this anyone on here? 43 seconds in video is an Allis.
Claus
Joined: 09 Dec 2009 Location: Hebron In Points: 1166 |
Posted: 06 Feb 2011 at 10:44pm |
Nice looking rig, trailer and load!
acd21man
Posted: 06 Feb 2011 at 10:45pm |
looks good
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4988 |
Posted: 06 Feb 2011 at 10:55pm |
Nice video,love all the gear shifting at the end.Looks like it would take some time to learn.
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
ToddSin NY
Posted: 06 Feb 2011 at 10:59pm |
The idea of the video is the twin sticks and shifting them. The Allis is a bonus!! LOL!!
dustinmo
Joined: 12 Sep 2009 Location: Auxvasse, MO Points: 2187 |
Posted: 07 Feb 2011 at 7:38am |
that there be a 2 stick mack with a little window in the back and a bulldog ready to attack
Jim Lindemood
Joined: 22 Sep 2009 Location: Dry Ridge, KY Points: 2569 |
Posted: 07 Feb 2011 at 7:46am |
Wow, that is one nice 'ol truck - and rig!! Pretty nifty shifting. The Allis grader is pretty sharp, too. Just pull the whole outfit into my barn and leave it. I'll gladly give it proper feed and water -- LOL. |
Steve Wilkens
Joined: 12 Sep 2009 Location: Ceresco, Michig Points: 447 |
Posted: 07 Feb 2011 at 8:33am |
Bet learning to shift that thing that smoothly took time
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25242 |
Posted: 07 Feb 2011 at 8:56am |
Only two sticks....piece of cake to use..
My '58 Willys 4WD pickup had FOUR sticks, plus 2 more for the PTO.
3 speed stick, Overdrive stick, 2 sticks for the 4WD transfer case.
Now that was a real challenge!
DonBC
Joined: 12 Sep 2009 Location: Courtenay, BC, Points: 947 |
Posted: 07 Feb 2011 at 12:41pm |
That is a real talent to make all those shifts and never touch the clutch pedal. Years ago when the construction company that I worked for was short of staff I had to deliver a pickup to the crew at a job site about 100 miles away and bring back the old Mack B52 and empty lowbed to our yard in the city. The guys gave me a quick course on shifting the 5 plus 4 transmissions and the air brakes. They also gave me the route to take to avoid the weigh scales since legally I shouldn't be driving a semi. The trip went well and I was able to make some shifts without the clutch on the main transmission but with hills and stops and starts in the city I did enough clutch work that my left leg muscles were so stiff the next day or two that I could hardly walk. That was my one and only experience driving a semi or truck with an auxiliary transmission.
Reeseholler
Joined: 28 Mar 2010 Location: Port Matilda PA Points: 294 |
Posted: 07 Feb 2011 at 1:18pm |
that is sweet. Wish I had something to fiddle around with like that. That would be something that I would really like to learn.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42264 |
Posted: 07 Feb 2011 at 1:28pm |
I have a 5 X 4 in my White but the Fuller boxes are not syncro in any gear so the double clutching is a must. Once moving one box can be split into direct or over then backshift to direct and up one gear in main, none of it as smooth as that video.
Jeff(WD45-SATX-TN)
Joined: 13 Sep 2009 Location: Sewanee, TN Points: 443 |
Posted: 07 Feb 2011 at 1:29pm |
That was very impressive. Have seen those old twin sticks sitting still in shows and such. Never have seen one in action. I'm sure that gentleman has some serious seat time behind the wheel of that old truck. SWEET! |
1954 WD45 NF "Iron Tater"
Claus
Posted: 07 Feb 2011 at 1:36pm |
In 1979 Dad went from a 1969 Hendrickson 318 Detroit 16 speed to a new Mack 300 5 speed, he loved it.
NickT(Ky)
Joined: 13 Sep 2009 Location: Elizabethtown, Points: 417 |
Posted: 07 Feb 2011 at 9:33pm |
Yeah, I've drove the 5 x 4 and it ain't that smooth. But it wasn't a Mack tho.
Texas B
Joined: 04 Aug 2010 Location: Pointblank, TX Points: 99 |
Posted: 08 Feb 2011 at 3:12pm |
my 1st time to drive a semi was in ND in a cab over Freightliner Twin stick Cummins - only had to pull over once goin up a hill, got lost in the gears - down shift was a two handed job - up was usually good with one without the clutch. At night no less. Sittin high, heavy load, dark, tired, etc - made it.
Texas B 39
orangepower
Posted: 08 Feb 2011 at 7:47pm |
looks like you need to be an octapus to drive one, reminds me of the time backing a wagon in the barn with a JD B no power steering and that stinking hand clutch.
45 diesel puller, 45 gas puller, ca puller
JR Maley
Posted: 09 Feb 2011 at 1:51pm |
My '97 Jeep TJ had 4 sticks. One for the front axle high range/low range/neutral, one for rear axle high/low/neutral, one for the 5 speed transmission, and one for the cable actuated front locker. It was all for four wheeling, but the fact that all the transfer case gears were synchro made hauling hay wagon trains and other very heavy loads easy for the little jeep. I would go through the 5 tranny gears in low range (4.3:1 under drive), then shift on the fly to high range. I was alot like driving that Mack. I honestly miss that Jeep.
Rawleigh
Joined: 14 Sep 2009 Location: White Stone, VA Points: 421 |
Posted: 09 Feb 2011 at 5:00pm |
I'll stick with my 9 speed Fuller!!
Rick of HopeIN
Joined: 11 Sep 2009 Location: Hope, Indiana Points: 1329 |
Posted: 09 Feb 2011 at 8:43pm |
Neat video, have heard the older drivers talk about those twin sticks. I have hard enough time keeping track of two range selector switches. I seldom drive anymore and a lot of our test trucks now run the electronic shift boxes.
