Source for 262D Cam and Crank Gear
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: Source for 262D Cam and Crank Gear
    Posted: 06 Feb 2011 at 2:02pm
Hi guys,
Looking to see if anyone knows where a guy can pickup new cam and crank gears for this 262D.
Agco wants $40 from the crank one (not too bad) but $350 for the cam one.  Ouch!
Thanks
Terry
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Kraig (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kraig (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2011 at 2:08pm
I needed a cam gear for my 262D and got one from All States Ag Parts in Wisconsin. They are on the web.
Kraig
7010,D17D,WD45,WD,WC,WC,B,
Gleaner K,60,66,72
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2011 at 3:10pm
The gears are the same on most 262 gas and diesel. I came across a cam gear the other day out of a gas that didn't have the 3 taped holes for pump drive gear.    MACK
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2011 at 3:14pm
I have spare cam gear[s] from 230 diesel, will they work?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2011 at 7:07pm
I think a new or reground cam is available from Valu-Bilt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2011 at 7:13pm
If you get a cam from Valu-Bilt, have the casting numbers ready when you call. If I remember correctly, they said there were 4 choices. The early cam choice is the same as the 230 and they didn't want my old one for a core. Gears? Can't help there.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2011 at 7:19pm
I think I have a set up in the loft...let me know if you don't find any and I will go searching....
ALLIS EXPRESS!
This year:
