WD45 throttle issue
jdsellers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdsellers Quote  Post ReplyReply Direct Link To This Post Topic: WD45 throttle issue
    Posted: 04 Feb 2011 at 11:57am
I've got a WD45 that was rebuilt a while back.  It had WC pistons put in the 45 block, which bumped up the compression ratio.  The engine runs great, but the throttle response lags then overshoots.  What I mean is that when you throttle up it's delayed for a split second.  Once it revs it doesn't ever want to stop and will essentially try to overrev.  Now when you start to throttle down you can balance it out somewhat, but the throttle balance is delicate because it's in a different spot when the engine is loaded and unloaded (just cruising around).  The only troubleshooting done was to replace the governor with a spare, but no change in function.  I haven't checked the timing yet, it may be too advanced?  I don't remember anything else that was done to it.
Does anyone have any suggestions on what to look for?
Thanks
JD
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 1:07pm
Did the spare govener work right?
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 1:14pm
Is something binding on the throttle rod, maybe the carb butterfly valve is sticking?  But I would suspect the new govenor also?
Still in use:
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 1:24pm
sure sounds like the linkages are sticking, unhook the rod from the governor arm and the carb and see if everything moves freely, also check bushing on the governor shaft that goes through the front cover
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdsellers Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 4:01pm
It was another old governor that was tried.  Who's to say that it was any good, it just acted the same way with either one so I sort of ruled it out at the time.
Thanks for the insight guys.
I will check it out and let you know what I found.
Edited by jdsellers - 04 Feb 2011 at 4:03pm
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 4:12pm
Make sure that the linkage that comes out of the governor goes across the front of the engine and pulls on the carb moves freely my WD started sticking their a couple years ago and acted like that.
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 12:02am
Hmmm... how's ignition timing?  What's the chances your advance weights are binding, and once it picks up enough, they swing out, and won't swing back?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 12:08pm
What about governor adjustment? With the throttle lever opened wide, the link from the governor should be able to travel about 1/8" past wide open on the carb when disconnected. If the governor isn't adjusted right, it might be your problem.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 6:40pm
  i am with  BRIAN  start from scratch with the governor adjustments   differnce in governor wear can cause your problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 9:37pm
Shorten the linkage between the gov. arm and carb. by bending it down if every thing is free.    MACK
