AC WD45 ENGINE BORE SIZE
Brian in WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian in WI Quote  Post ReplyReply Direct Link To This Post Topic: AC WD45 ENGINE BORE SIZE
    Posted: 02 Feb 2011 at 4:26pm
I have wd45 with a 4" bore dome piston in it.  It is a 1956 model. Did 45's come with 4.125 bore?  I also have a LP block with letters GH on end of # stamped in block. This one also is only a 4" bore with a high comp. piston in it. So can someone answer my question. Did someone  put these in the motors or did they come that way.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2011 at 4:33pm
A WD45 came with 4" bore stock, there were kits to make them 4-1/8".
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2011 at 4:55pm
They came with a 4" dished piston.
Wink
I am a Russian Bot
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2011 at 5:25pm
The  LP45s came with WD pistons for the 7.2 comp. I put  them in my 45 years ago with the overbore. I believe they are the dis low compression pistons. I do not think any WD pistions were dished.
