WC rearend ?
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: WC rearend ?
    Posted: 02 Feb 2011 at 7:20am
I have a WC non war rearend and have a question. At the lower part of the final drives are a set screw to hold the axle in place then right above the setscrew is a threaded hole. what's this hole for? They both drip gear grease.
Gary in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2011 at 7:42am
I thought that was a vent/drain hole.
If the seal leaks or get water in the brake area it will drain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2011 at 2:09pm
Can I get all the seals to fix this from agco? The rear end and final drives are the only thing I haven't taken apart and checked out and cleaned. I can make the gaskets but not seals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2011 at 2:11pm
I got the ones for my WC from Brenda, Sandy Lake imp.
and will need to get some more for the unstyled WC.
Edited by Gary in Texas - 02 Feb 2011 at 2:11pm
