Injectors 301-426 sizes
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: Injectors 301-426 sizes
    Posted: 29 Jan 2011 at 6:40pm
Will injectors from a 426 fit in the head holes on a 301 head ? I need some cores , saw some on Ebay and they are to a 7060
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 8:43pm
Looking at a couple of tractors on the AGCO parts book page, they are different.  Couple parts are the same but not the body.  Would help to know which tractor.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 10:00pm
Yes the injector bodys are the same. The later 301s with the copper sleeves in head use a different cap to hold the tip to body but bodys are the same.     MACK
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 1:04pm
pm me what you are wanting to do. 190XT through 7060 did use the same injectors on the Allis style, with the exception of the 2900MKII in 7000, 7010, 7020 etc with copper tubes in head like MACK stated. The return caps differ slightly too through the years, from being sealed with 2 copper washers, to an oring inside. It can be a little confusing when swapping things around. Let me know. Ed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 3:45pm
doug, tried to pm you, your box is full! Ed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 4:04pm
Now its not , sorry bout that
