wd starter
scruffy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scruffy Quote  Post ReplyReply Direct Link To This Post Topic: wd starter
    Posted: 29 Jan 2011 at 12:01pm
help needed, is it normal for a wd to tear up a starter? this is the third starter, The first one broke the nose cone. The second was the drive spring and just now the nose cone and twisted off the armature shaft..is my timing at fault
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 12:20pm
It sounds like to me either the engine is kicking back ,to tight or its being lugged down to the point of dieing and rolling backwards or the hold down bolt is loose.
Edited by mlpankey - 29 Jan 2011 at 12:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote scruffy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 12:38pm
This has always happened when the engine kicks back.I have been looking for that adjective to describe what it did,(brainey) The motor has roughly 200 hours on a major.
amac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amac Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 1:00pm
Do you have a 6 volt starter on a 12 volt battery? that would be a good commbination to fly apart when the engine kicks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote scruffy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 2:02pm
still has the 6 volt pos ground system. thanks
RSponenberg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RSponenberg Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 2:19pm
Only difference in 6v and 12v in a starter for a WD is the winding!! They both use the same nose, bendix, and sping!!!
You have a timing problem...
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 5:43pm
Pull the distributor cap and the rotor, the shaft under the rotor is hollow and has a felt wick in it. Oil that wick, it oils the spark retard assembly. In this case check that assembly because it is stuck it the run position, which causes the engine to kick when starting and brakes the starter.
Dusty
This page was generated in 0.083 seconds.
