New member
MNfarmerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNfarmerAC Quote  Post ReplyReply Direct Link To This Post Topic: New member
    Posted: 28 Jan 2011 at 10:56am
Just joined and thought I'd introduce myself.  I farm about 350-400 acres of mostly hay ground and some oats once in a while.  I have about 35 head of beef cows and as of last year my main tractors are AC.  I had a JD for a while but sold it.  As my signature says I have a 1971 170 that I got from the original owners with ( they figure) about 10,000 hours on it.  A 1974 185 with dual PTO that has been here since the mid 80's with about 5,000 hours.  My latest acquisition was last spring, a 1977 185 with a cozy cab single PTO and a little under 3,100 hours.  Just found out from an oil sample that it has very high levels of iron and lead in the oil, surprising considering the hours!  I figured there was something wrong as last summer it burned about 3 qts. of oil in a hundred hours.  Other than that problem, the tractor is in excellent original condition.
Brandon
1974 185
1977 185
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 11:10am
Welcome lots of great info hear!
Randy
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 11:11am
Welcome to the Forum. You will find a vast knowledge base here on everything Allis Chalmers. Ask away with questions, lots of advise and experience here. Everyone likes to see tractors too, so when you get some time, let us check out your line up.
Jeff
1954 WD45 NF "Iron Tater"
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 11:13am
Welcome!  In my opinion you own two of AC's best tractor models.  You'll like it round here.
Edited by Claus - 28 Jan 2011 at 11:14am
David Gibson (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gibson (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 11:17am
Welcome!
David Gibson
http://www.darkecountysteam.com
1956 WD45
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 11:37am
Welcome!!! I know you will find the knowledge you want here.  I can't be of much help though since we closed our dealership in 1962 well before your tractors were sold new.
That said, Welcome again!
Good Luck!
Bill long
Richmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richmar Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 12:19pm
claus:
Was wondering, where did you get the exhaust pipe for your one seventy?
I have been looking , but can not find one that fits the pipe that come out of the manifold on my 170 gas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richmar Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 12:21pm
     I should have said (comes) out.  Sorry     Richmar
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNfarmerAC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 12:22pm
Thanks for the welcome everyone!  When i get my pictures ready to post, should I post them here or in the image archive?  I haven't been able to pull up the pictures in the archive for a long time and I'd like to put them where they can at least be looked at.
Brandon
1974 185
1977 185
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 12:36pm
Many of us have an account on www.photobucket.com Uploading the photos there and using the links they provide to post on here works best for me.  Welcome to the forum.
Edited by redline - 28 Jan 2011 at 12:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 12:36pm
Welcome Brandon, The image archive hasn't worked in a loooong time. I think the best place to put pictures is photobucket.com. Get a free account set up and upload your pictures there. When you want you can copy and paste the IMG line here and the pictures will show up or you can make your page public and post a link to it so we can see all your pictures. If you upload them to this site, your image files will soon be maxed out for the site. In order to upload more pics, you will have to delete others and then they don't show up in your older posts.
 Hope you can do some fixin on the 185 before anything bad happens.  Charlie
Kip[NY] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip[NY] Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 12:47pm
Welcome aboard, Brandon.  You won't find a nicer and more helpful bunch than right here.
Kip
1959 D-14 SN/21089 "Martha"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 12:47pm
Originally posted by Richmar Richmar wrote:
claus:
I bought that pipe from Steiner Tractor parts.  When I bought it they did not offer one for a late D17 Series III, IV or 170 so I had to cut the bottom off and slide the pipe over the pipe that threads into the exhaust pipe.  Now I believe they offer a chrome exhaust stack with threads for the later manifold.
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 4:04pm
Welcome -- lots of good folks here that share lots of good info.
TerryMtAuburnIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TerryMtAuburnIA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 4:21pm
welcome
Reeseholler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 5:44pm
Welcome. Hope you enjoy your "stay"
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 6:26pm
Welcome aboard neighbor.
D17 owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17 owner Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 6:34pm
Welcome, like others have said there is a lot of info. on here. I love this site, on here every day.
Anthony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 12:08am
Welcome to the room, nice to meet you
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 3:26am
welcome to the forum brandon! these guys on here ARE the BEST! they have helped me alot of times with my tractors....and ummm.. a few other things too!!
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 4:17am
Welcome aboard Brandon. Hope you can make the GOTO up in Minnesota the middle of July. If so, many of us will meet you then. God Bless.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNfarmerAC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 6:03am
Where is the GOTO at this year?
Brandon
1974 185
1977 185
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 7:23am
The GOTO is at Hutchinson on July 22-24.
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 7:23am
Ft. Meade Florida....you can check out the specifics on the Events part of the Forum.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 8:11am
welcome to this wonderfull site
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 7:35am
Welcome, fellow Minnesotan!
