WD dual wheels
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Topic: WD dual wheels
    Posted: 26 Jan 2011 at 11:08am
Has anybody seen these before and are they factory or home made.  I think I might make me a set of these out of a spare set of wheels I have laying around.
and here is the link were they are for sale on ebay
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 1:07pm
Looks like a split rim welded to a spinout center.
fordf350dually View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordf350dually Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 1:30pm
i saw a guy who used thos 2 have spin out duals on a wd. it was very cool
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 5:56pm
Yeah they've been on ebay for quite awhile....I posted them up here about 3 months ago.....they are pretty neat though....I wouldnt mind a set.
Edited by BennyLumpkin - 26 Jan 2011 at 5:57pm
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 5:58pm
Sorry, didn't know thatthey had already been posted I just thought they were interesting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 6:02pm
I wasnt knocking the fact that you posted them....I think they are a much cooler way to mount duals than just bolting them together.
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 6:23pm
Looks to me like they cut the bolt pattern center out of a spin-out wheel center and extended it with a piece of steel tubing.
 Denis, surely home made.
Edited by CTuckerNWIL - 26 Jan 2011 at 6:24pm
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 7:31pm
Looks easy enough, cut your tubing to length, sit on old hub, cut around it with a plasma torch, weld pieces together. Probably the toughest part is mounting the two on the tractor at the same time. I guess as tight as most hubs are, you could bolt down the first, remove bolts and then bolt on the dual hub.
ALLIS EXPRESS!
This year:
Bryan L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bryan L Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 8:48pm
I may have missed something here. On our WD We had an extra set of power shift wheels and rims. When we mounted them on for duals
we just used longer bolts in the hub on the end of the axle.
No need for adapters or anything else.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordf350dually Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 9:04pm
bryan. u just proved me right. my grandfather thought that wouldnt work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 9:12pm
Somebody else posted a while back that they will work that way...I think this setup lets you get the tires away from the fenders and gives a wider stance or else a wider gap between the duals.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 9:51pm
So it will work with regular wheels, I was going to try it on my discing tractor but didn't know if it would work I thought the inside wheel might wear the lug holes a little because it wouldn't have the cone of the lug bolt against it.
Thanks,
Denis
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 10:22pm
Did you turn the outside wheels backwards?
I am still confident of this;
Wait for the Lord;
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2011 at 9:07am
I prefer the clamp on with spacer bands.Quicker and easier.
Buster1 (Mi.) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Buster1 (Mi.) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2011 at 10:39am
I had a set of duals on a D-17 I  bolted to the hubs over the orignal wheels. I cut over sized holes in a pair of the dual wheels so I could leave two lug bolts on the tractor when putting the duals on. Safer and easier, it also left a pair of tapered bolts in hub to keep the inside wheel wheel from working on bolt holes.
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2011 at 10:46pm
Looks like a good way to break bolts if bolting two wheels to one hub if it's done for anything other than show. The one wheel fit's over a lip in the hub and this is what supports most of the weight with the bolts just keeping the wheel from falling off. When you bolt on another wheel it will just be supported by the bolts. Add the leverage of the dual sticking out there and I'd think the bolts would break if used very much.
If you want duals I'd use clamp-on duals myself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 10:17am
Spacer band clamp on wheel is much simpler and easier to put on and take off.Like m16ty says,I don't know how you expect to not have problems with no pilot on the outside wheel.
