horsepower requirments for cultivator
Matt (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (NEIA) Quote  Post ReplyReply Direct Link To This Post Topic: horsepower requirments for cultivator
    Posted: 26 Jan 2011 at 12:19am
Is there a set rate of horsepower requirements for a cultivator, like say for example 15 horsepower per row or something?  I would be using a rear mount cultivator in black iowa sod.  Thanks!
1955 WD-45 with factory PS
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 1:43am
I've seen them listed in a text book on designing ag machinery. In my uses of a row crop cultivator, my MF-135 had no trouble pulling a cultivator doing 6 rows narrow. It had trouble lifting it after the transmission oil heated up. I think the cultivator bar had been filled with scrap steel at the factory with the ends welded shut to keep it from floating and it was effective and heavy. And the same tractor pulled a light weight 12' wide field cultivator pretty good. Both were green.
Gerald J.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 7:08am
We always used our 7030 or 7045 to pull a 6 row but that was or smalest tractors excep our farmall smta .
Allis Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 7:16am
I use to cultivate 2 rows with a john deere H. that is rated at 12.5 hp.
Allis orange blooded by family. Allis Diehard by choice
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 9:04am
We pull a 6 row narrow with a 2-70 white, and it handles it no problem, and has no trouble lifting it.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 11:27am
We ran a two row front mount on a JD B and that was a load...first gear going up hills. We also had a front mount 4 row on the WD45D and that wound give it a workout in 3rd gear. A lot depends on how many and how wide of shovels total and how deep...we had wide rows and 6 shovels per row. I've only seen WD's set up with two row front mount.
ALLIS EXPRESS!
This year:
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 11:40am
The guy I work for has a glenco 12 row that he pulled with a 7000 no problem he had more trouble turning around than he did pulling it he bought it and used one year when he had a herbicide failure
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 4:44pm
I did a lot of cultivating with a 300 Farmall (30 hp) pushing a 4 row cultivator in my youth.  It was a good cultivating tractor (among other things) in it's day.  In fact, a good tractor today if you can get along without a cab.   Power steering, 3 independent remotes, a TA, big diameter tires, and more than enough power.
If I remember right, I used 4th gear and a reduced engine speed.
Mark
GTH-L Simplicity
Mike NEIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 5:12pm
Pulling it isn't really a problem, It's how much weight do you need on the front and will the hydraulics lift it? I pulled an 8 row wide brillion with our XT 190 but had trouble lifting it.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 5:15pm
I agree, weight may be a problem.  You do need enough weight to control the cultivator.
This page was generated in 0.062 seconds.
